Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Clicking Sound While Riding
While riding the board or just spinning the wheels, there is a constant clicking sound.
Pulley Bearings Worn Down
It is likely that dirty bearings are causing the noise and need to be cleaned. If cleaning doesn’t work, replace the pulley bearings with this guide.
Skateboard Bearings Worn Down
It is likely that dirty bearings are causing the noise and need to be cleaned. If cleaning doesn’t work, replace the skateboard bearings with this guide.
Grinding Sound While Braking or Accelerating
When trying to brake or accelerate there is a loud grinding sound
Belts Are Not Tightened
It is possible that there is not enough tension on the pulley belts, try tightening the belts.
Board Won’t Power On
When pressing the power button on the board, the board will not turn on
Battery Not Sufficiently Charged
It is possible the battery is low, plug in the board to the power adapter. After an hour, check the battery level. If this doesn’t work a replacement battery is needed. Contact the manufacturer and send the board in for a replacement.
Battery Charger Malfunction
Make sure the green power indicator light is on. If the indicator light does not light up, check the charger for the board to see if there are any loose connections. If there are no visible loose connections, a replacement battery charger will be needed.
Board Won’t Accelerate or Brake
When trying to accelerate or brake nothing happens
Belts are Broken
It is possible that the belts have snapped, check to see if the belts are in working condition. If not, replace them with this guide.
Motors Worn Down
It is possible that the motors are worn out and need replacement, contact the manufacturer for replacement information.
Wheels Won't Spin Freely
Wheels won't spin freely or, while riding, the wheels seem stiff and you don't move far
Wheel Nut too Tight
Loosen the nut slightly until the wheel spins freely, be sure to not loosen it too much or risk the wheel falling off.
Skateboard Bearings are Dirty or Worn Down
It is likely that the dirty bearings are causing too much friction and need to be cleaned or replaced.
Remote Not Charging or Low Battery Life
The remote doesn't seem to hold a charge or there is always low battery life
Battery Is Dead
Your battery remote may be low or dead. If charging the remote does not solve this problem and you suspect you have a faulty battery, you’ll need to replace it with this guide.
Author
with
Kyle Trambley
293 Reputation
1 Guide authored
Cal Poly, Team 15-7, Livingston Fall 2016 Member of Cal Poly, Team 15-7, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G7
4 Members
72 Guides authored
4 Comments
my board has 51% battery life and when I try to turn the power on I get a flashing red light and the board won't turn on.Please help?
Mark Laquis - Reply Share
Mine does the same thing have found a solution to fix it?
Chris - Reply Share
Mines doing the same but the red light flashes in the board then powers off the charger stays on a green light even while plugged into the board. It’s a brand new board just bought last week.
chaun1234 - Reply Share
Won’t turn on , just a red light flashes 3 x. … … … what do I need to do?
Robert caruso - Reply Share
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 35
All Time: 9,264
