Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Blu Studio Selfie Does Not Turn On
Tried everything, but doesn’t want to turn on.
Power Button Is Stuck
Before you force anything that can lead to major damage in your phone, check if the problem is just that the button is stuck; look for any stiffness in the button or if it won’t move at all. It is usually visually noticeable if the button is stuck. By removing the back you can easily fix this issue, since it is the back case on which the button usually becomes stuck. Make sure you place back the back cover correctly when you are done.
Bad or Uncharged Battery
If you are certain the issue is not with you charger and your battery is indeed charged then it might be time to purchase a new battery. One can be found relatively cheap online. Before resorting to that however, check to see if your charger is working by using it on another device. If nothing has fixed the problem yet it could be your battery, here is an article on how to check if the problem really is your battery.
Display Not Working
If none of the solutions helped, you might consider that the display is malfunctioning. Contact you closest retail store or go to their website and contact them directly.
BLU Studio Selfie Is Frozen/Does Not Respond
Characterized most commonly an image on the screen not responding to interaction of any kind.
Phone Is Loading
Take a deep breath, and see if your phone comes back after a minute. The reason might be and app loading in the background or that your phone capacity is at the maximum. Try clearing some memory.
Physical Damage
One reason that your phone is frozen is because of a physical damage. A drop, extreme temperature, or even pressure can affect the performance on your phone, if this happened you need to contact a technician to get an analysis of the part that needs to be replaced.
Camera App Does Not Open
Try Restarting Your Phone
Whenever you see that your phone is working slow, or that some apps do not want to open, do a hard reset. The hard reset will close everything, and restart completely your phone. First, turn your cell phone off by pressing the single button on the left side, and then choose turn off. Second, hold the power and the low volume button together until a litle black and white screen shows up, and choose normal boot. The hard reset is complete.
BLU Studio Selfie Will Not Charge
Phone does not get charge after being plug to a power source .
Broken/Dirty USB
Look for any damage that might be causing the malfunctioning. Try to use different chargers if the problem remains unresolved. Check the power port on your phone (where you plug the charger in), clean out anything that shouldn’t be there by: 1) Blowing compressed (canned) air into the charging port, 2) Using a cotton swab to gently clean out any dust in the port, 3) Wrapping double sided tape around a thin but sturdy object (a needle for example) then roll it around the inside of the power port to remove any lint that might be inside. Try charging your phone again, if it still does not work it is probably time to purchase a new battery.
Low Power Input
If you are charging your phone using a charging cable that is either old, or not the original, it is possible that the problem is you’re using the wrong cable. For a guide on picking the right charger you can refer to this article.
No Audio Output On Blu Studio Selfie
Volume Buttons
Before you force anything that can lead to a major damage in your phone, check if the problem is just that the button is stuck, look for any stiffness in the button or if it won’t move at all. It is usually visually noticeable if the button is stuck. By removing the back you can easily fix this issue, since it is the back case on which the button usually becomes stuck. Make sure you place back the back cover correctly when you are done.
Bad Phone Speaker
Another cause might be that the speaker is not working. Try getting help form a technician or go to this link on how to fix internal smartphones speakers.
Author
with
Stacy Kam
630 Reputation
5 Guides authored
USF Tampa, Team 10-1, Remmell Spring 2016 Member of USF Tampa, Team 10-1, Remmell Spring 2016
USFT-REMMELL-S16S10G1
4 Members
72 Guides authored
2 Comments
how do i reconnect my selfie back on when i unistalled it for certain reasons so i can use it on my laptop again because every time i do the usb says it is not recognized because it is unavailable
orizaba1990 - Reply Share
Why does my front camera for me to take selfies so it's not detected I need to know what to do
libby dangelo - Reply Share
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 22
All Time: 4,832
