Phone Will Not Charge
No matter what you do, you cannot get your phone to charge.
Dead Battery
The battery in your phone may be dead. See the replacement link on how to replace the battery. BLU Dash Music 4.0 Battery Replacement
Faulty Charger
Try using a different charger or possibly buying a new charger as yours may be broken.
Broken Wall Outlet
The wall outlet you are using may be broken. Try charging your phone using a different outlet.
Replace the Charging Port
If none of the above suggestions work, then you will have to replace the charging port: BLU Dash Music 4.0 Micro USB Port Replacement
No Audio
There is no sound coming from your phone, with or without having your headphones plugged in.
Adjust the Volume
Try turning the volume of the phone up. Do this by using the two volume buttons on the upper left-hand side of the phone.
Restart the Phone
You may need to restart your phone. You can do this by holding down the power button until an options menu pops up. You can select "power", "airplane mode", and "reboot". Select "reboot" from the menu to restart the phone.
Replace the Speaker
See replacement link on how to replace the speaker. BLU Dash Music 4.0 Speaker Replacement
Phone is Frozen/Unresponsive
When you touch the screen of the phone to do something nothing happens.
Low Battery
A low battery may cause your phone to either freeze or become unresponsive. Try charging your phone using a wall outlet or USB adapter.
Restart the Phone
Adjust the Battery
If the phone is unresponsive to the point that it will not let you restart, you may need to adjust the battery. Try removing the battery by first removing the back cover of the phone, then removing the battery; this will shut the phone off. Now put the battery back into place. The put the back cover on the phone. Next, try to turn the phone on again by holding down the power button for a few seconds.
Phone Will Not Turn On
No matter what you do your phone will not turn on.
Try the Power Button
You may not be holding down the power button down long enough to turn the phone on. Press and hold down the power button for about 10 seconds.
Charge the Phone
The phone's battery may be dead; if so, it needs to be charged. Charge your phone using either a wall outlet or a USB adapter.
Replace the Battery
Phone is Running Slow
When you do something on your phone its takes longer than normal to function.
Restart the Phone
Close Open Applications
You may have too many applications open, which can cause your phone to run slower than normal. To close the open applications that you are not using, hold the home button and swipe each application to the left or right with your finger.
Delete Some Data
Having a lot of pictures and videos stored on your phone may cause the phone to run slowly. This is because they are taking up a lot of data and memory on your phone. To delete unwanted pictures or videos, go to your gallery and select the pictures and/or videos your want to delete. You can do this by clicking on the "settings" button and then selecting "delete".
4 Comments
My phone is stuck on the start up screen and has to remove battery to switch off. How do i fix this?
Dinah White - Reply Share
I bought my son this phone and I put his Sim in it and it is not working this is so frustrating
manningmom.sm - Reply Share
I lost my other phone I think I was found and reset but I'm logged into the email that I sent the phone up with on this phone because I had the two linked. Can I lock the phone up even if my other phone was factory reset?
Melissa Emerick - Reply Share
Lap limen e tèn
Ayneuvemerone - Reply Share
