Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Toast-R-Oven won't turn on
No matter what you do, you can't get your Toast-R-Oven to turn on.
Check if the oven is plugged in
If it still does not turn on, your problem most likely lies in the power connection.
Check to See if the Red Light is On
If the red light is off while the device is plugged in, then the power unit is most likely faulty and may need repair or replacement
Feel if oven is warm
Even though the display is blank, the oven might still be on. If this is the case, your problem most likely lies in the display.
One of the toast/bake functions does not work
"If you are only able to perform one of the two functions for the oven."
Check to see if knob is intact
The knob might be turning but not fully registering to each of the settings. Try to feel for a definite click when changing settings.
Check to see if the internal temperature actually matches the display
If the temperature settings are not consistent with the factory default, the oven might have a problem with the thermostat.
See if both heating elements are working
If only one of the heating elements turns on, no matter the setting, then a replacement element will probably be needed.
Exterior parts are broken
"If certain exterior elements aren't functioning, you might have smaller problems then you think."
Door is loose
If the door does not close all the way the spring is likely broken or stretched, and you will need to replace the spring.
Black and Decker Toast R Oven Door Spring Mechanism Replacement
Front glass is cracked
If the glass panel on the front of toaster oven is cracked or broken you will need to remove it and get a replacement glass panel.
Black and Decker Toast R Oven Door Replacement
Knobs broken/don't stay on
Most likely your knobs are cracked so they no longer say on. If this is the case then you will likely have to buy replacement knobs and put them on (this should be an easy fix).
Black and Decker Toast R Oven Knobs Replacement
Food isn't being cooked to the proper extent
"If your food is always coming out undercooked or overcooked, there might be a few internal issues."
Timer isn't functioning properly
While the heating elements might be working well, if the timer isn't synchronized, your food will not turn out the same. An additional problem could be that the switch is malfunctioning.
Black and Decker Toast R Oven On/Off switch Replacement
Optimal temperature isn't being attained
For this problem either the heating elements need to be replaced or the thermostat needs to be calibrated.
Burning smell emanating from toaster
Food and crumbs built up in bottom of toaster
This smell is most likely due to food and crumbs and that have built up on the bottom of the toaster. The best way to eliminate the smell is to disassemble the casing and wash all the panels individually.
How to clean out a Black and Decker Toast R Oven
Jonathan
320 Reputation
5 Guides authored
Cal Poly, Team 2-10, Propen Fall 2012 Member of Cal Poly, Team 2-10, Propen Fall 2012
CPSU-PROPEN-F12S2G10
4 Members
60 Guides authored
11 Comments
HOLDING both door firmly closed and HOLDING"on" button until it is lit
results in "on " button not remaining lit.
Yes, unit is plugged in. Yes, the obvious knobs have been altered to every conceivable position. Yes, the tab on the door is inserted in its slot properly. Even artificial depression of the mechanism which the door tab is to hold results in NO CHANGE in above problem. WHY will "on" button, which lights briefly when held NOT STAY ON?? How can this be fixed??
HOW IS THIS TO BE FIXED????
fkpaine - Reply Share
Mine won't turn off. Turning it to off, it dings and then the knob springs past “off” directly to the “stay on" setting
Ian yarbrough - Reply Share
Toast only browns on the top,bottom stays white.
Jean Hall - Reply Share
The fan no longer works
Keith Mercier - Reply Share
Haw to use it?
Erwin Baeza - Reply Share
Past 24 Hours: 4
Past 7 Days: 8
Past 30 Days: 73
All Time: 37,138
