Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Switch devices using a media card
Going from old an old BB phone to a new BB phone.
BlackBerry 7.0 OS Setup
First, tap Search button and then, type in Device Switch. Setup should appear in the search results. Click Setup, followed by Device Switch, then select Using a Media Card and Save Data. Delete saved emails as they will be transfered later. When your content has been saved to a backup file, replace the media card with your new BlackBerry Z10 device. When the Device Switch screen appears on your BlackBerry Z10 device, type in your backup file password. The items will then begin to transfer over to your new device.
Reboot BBZ10 device
When your phone won't turn on.
Restart your BBZ10 device
Begin by pressing down the Power/Lock key and then tap Restart.
Reset your BBZ10 device
Press and hold down the Power/Lock key for at least 10 seconds.
Recover BBZ10 device
How to restore your phone when it doesn't turn on.
Shut down the BlackBerry Link program (and BlackBerry Desktop Software if available). Detach all devices that cannot be restarted. Open up BlackBerry updates on your web browser. Click 'Check for Updates'. Then, connect your BBZ10 to your computer. Restart your phone by holding the power button for 10 seconds until it turns back on. A prompt will pop up on the computer. The BBZ10 will appear in the drop-down list. If the LED blinks twice and turns off, press 'OK' within 15 seconds. Once the phone is turned on, a message on the screen will say Checking for BlackBerry Device Software updates.
OS Software problem
OS software acting up.
Reinstall program
Open the Blackberry Link software on your computer, be sure that your device is plugged in. Select Preferences, which can be found in the top right-hand corner, and then select Reload Device Software. Select the Reload option and the software will then ask you to hold down the power button for about 10 seconds (or til the phone turns on). The device should be detected and the operating system should begin to download. Your device should be ready to update and reboot.
Volume/Speakers
No sounds are coming out of your phone.
Speakers not working
Open the back cover. Locate a small grill for the speaker, which is just below the battery. Then, press it down. If you cannot locate it, it helps to play music to find right area.
Author
with
Emie Lou Cruz
1,099 Reputation
3 Guides authored
CSU Fullerton, Team 1-2, Bruce Fall 2014 Member of CSU Fullerton, Team 1-2, Bruce Fall 2014
CSUF-BRUCE-F14S1G2
3 Members
36 Guides authored
25 Comments
Verry good. Now my BBZ10 has sound . Thanks
nicu oancea - Reply Share
Thanks alot, awesome my phone has audio again - great help! was about to get another phone as the sound was only playing through the earphones
Zeyn Shahzada - Reply Share
my phone wont delete contacts. never seen this before. i turned off, removed battery, sim card and nothing works. At this point they want to charge me to help resolve this. wow.
cwalkerexcel - Reply Share
It Works. Great Tip.
imsasi - Reply Share
My BlackBerry z10 set getting switching off automatically, while using pls assist me wt to do
santosh - Reply Share
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 51
All Time: 45,509
