Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
The car will not turn on
The car will not turn on!
Switch turned off
Make sure the switch is in the on position.
The batteries are not installed
Batteries are required in order for the car to run. The batteries are not included in the package, so make sure you have AA batteries to put inside the car and the remote. If you need help installing the batteries, refer to the repair guide.
The batteries are dead
If you have installed the batteries and the car still will not turn on, the batteries may be dead. Buy a fresh pack of batteries and replace the old batteries.
The car is not responding to the controller
The car will not move after pressing the buttons on the controller.
The controller is off
First check to make sure the switch on the controller is turned on.
The batteries in the remote are dead
Check your batteries in the controller. If you didn’t use fresh batteries, replace the old batteries with new ones. Also, if the battery in the controller is backwards, the controller won’t work.
Antenna is not extended
Be certain that the antenna on the car is extended to its full length. If it is extended and the car still won’t respond, you may need to replace the antenna. Refer to the replacement guide for help.
Car won’t steer correctly
The car won’t respond to the remote control actions or go in the correct direction.
Wheels are worn out
If the wheels are worn out, the car may not go in the correct direction you want it to go. Try replacing the wheels.
Axle is stuck
Objects can easily get stuck in between the wheels. Turn the car over and inspect the wheels to make sure that nothing got caught in them.
Led lighting is out
The lights are not on when the car is on.
Led lighting is burned out
Your led lighting might be burnt out. You should replace the LED light bulb. For help, refer to the replacement guide.
Author
with
Amber Ashley
365 Reputation
4 Guides authored
USF Tampa, Team 1-6, Leahy Fall 2015 Member of USF Tampa, Team 1-6, Leahy Fall 2015
USFT-LEAHY-F15S1G6
3 Members
48 Guides authored
2 Comments
How do I get things stuck in the wheels out?
Unknown - Reply Share
Car response for 5 sec then I can only move wheels
Jeryl Knotts - Reply Share
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 41
All Time: 2,405
