Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Beats Pill XL Won't Connect Via Bluetooth
Pair was unsuccessful
Pairing a Device with Beats Pill XL
Check Bluetooth Connection Steps
  1. Turn on the Beats Pill XL and hold down the 'b' button until it pulses white.
  2. Activate your Bluetooth device and search for the pill.
  3. Select Beats Pill XL.
  4. Successful pairing will occurs when the Bluetooth status indicator is solid white.
    • Bluetooth Status Indicators
      • Off - Off
      • On connected - Solid white
      • On Unconnected - Off
      • Pairing - Pulse white
      • NFC Touch - 2 Blinks
Try Resetting the Device
  1. Turn on the device.
  2. Press and hold the 'b' and power button for 10 seconds.
  3. The LEDs will blink white and red 3 times, indicating it has been reset.
Replace Motherboard
If all else fails, the motherboard will need to be replaced.
Please follow the steps in Beats Pill XL Motherboard Replacement.
Battery Won't Hold a Charge
Battery doesn't last the advertised amount
Check Battery Level
  • When device powers on there are five indicator lights that light up depending on the battery level. These are located next to the power on button.
  • If one light shows up, it means you battery is depleted and needs to be charged.
    • Charge until an 5 indicator lights are on upon start-up.
Using Charge Out Feature
  • This speaker has an option to charge other mobile devices via USB cable. In doing so the battery will deplete faster, resulting in a shorter lifespan.
    • Unplug the mobile device for a longer lifespan.
Will not Charge
  1. Check if the outlet you are using is working. If not, try another outlet.
  2. Check if you charge cable works. If not, replace the charge cable.
  3. If both are fine, follow the link below on how to replace the battery.
Replace Battery
Over time batteries lose their charge and unfortunately need to be replaced.
Please follow Beats Pill XL Battery Replacement to replace the battery.
Speakers are Blown
Speakers are too low, too high, crackling, or popping
Basic Steps for Clear Sound
  1. Turn on the speaker and keep it playing.
  2. Adjust the volume on device and/or speaker.
  3. If plugged in via 3.5 mm audio cable, make sure it is fully inserted.
  4. If using Bluetooth, see if using a 3.5 mm audio cable fixes the issue. If so, try troubleshooting for Bluetooth.
  5. If speakers are still not clear, follow steps on replacing the speaker in the link below.
Replace Speakers
The speakers inside the Beats Pill XL are damaged and need to be replaced.
Please follow Beats Pill XL Speaker Replacement on steps to replace the speakers.
'b' Button Doesn't Respond
No matter what you do, the 'b' button has no purpose
    • NOTE: Skip this if the 'b' button isn't responding.
  3. The LEDs will blink white and red 3 times.
Reconnect/Replace the Connection for the 'b' Button Circuitry
The connection between the 'b' button and the motherboard is broken.
Please follow Beats Pill XL 'b' Button Replacement on steps to replace the 'b' Button.
Device Requires a Software Update
Can't figure out how to update the Beats Pill XL
Beats Pill XL Update
The Beats Pill XL will occasionally experience software issues.
  1. Connect micro usb cable that came with the device to the Beats Pill XL and to your computer
    • NOTE: Beats Pill XL supports Windows 7 and later or Mac OS X 10.8 and later.
    • WARNING: Do NOT use a usb hub.
  2. Go to Beats Updater
  3. Download the Beats Updater to your computer
    • NOTE: Remember where you save the file
    • NOTE: The file will be a .exe file for Windows and .pkg file for Mac.
  4. Follow the installation setup steps.
  5. After installing Beats updater to your computer, a registration webpage will appear on your screen.
  6. Once your Beats Pill XL is registered, the device will chime to let you know it's been updated.
    • NOTE: This may take a few minutes to update.
You will be able to rename your device after the update is done. If you do, you'll need to pair up again your Beats Pill XL with your blue tooth device.
Author
with
Alejandro Velez
125 Reputation
1 Guide authored
8 Comments
I want to know if theres a downgrade software becouse while im updating my beats the usb disconected accidentally and then my Beats Pill XL when im playing with bluetooth the speaker is out of sync or its late than the actual playing music on smartphone. can you help me?
King - Reply Share
Guys i just dropped my beats pill xl and its not turing on and battery light is on wat can i do
damasco60 - Reply Share
Any reliable service facility in my zip code area (20019) you may recommend? I haven't been able to turn on the beats pill XL. I've never turned it off since I ignorantly bought it years ago. Thanks.
Doris Pegram - Reply Share
beats pill LED won't stop blinking white and can't pair with my iphone. What can I do?
mona l ghaleb - Reply Share
I have a beatspill XL and it connects , charge , turns on perfectly fine . Now the problem is when it is connected to any device I can not hear the device through it
yailin41668 - Reply Share
Past 24 Hours: 0
Past 7 Days: 22
Past 30 Days: 129
All Time: 71,796
