If you are not sure which parts to print, which assembly to follow or what BOM applies to your upgrade, you are at the right page. This guide explains what applies to which version of your printer/upgrade.
We invite you to consult our FAQ or the official Prusa knowledge base for more information.
1. Bear Frame 2.1 Upgrade
Status: stable
The Bear Frame Upgrade improves stiffness and reliability of the original Prusa i3 MK2(S), MK2.5(S) and MK3(S). It allows faster prints, increases precision, makes maintenance easier and opens the door to more customization. Plus it looks unique with our colored frames!
- Bear Frame 2.1 Upgrade
4. Bear Extruder + X-Axis
Status: stable
This is a better extruder and X axis for Prusa i3 printer MK2.5S and MK3S. It is a following of the Bear Upgrade project and is still compatible with original Prusa's 3D printers.
The main goal of this extruder is to improve print quality, reliability and make maintenance easier.
⚠️ The Bear X axis is NOT compatible with stock Prusa extruder!
- Bear extruder page
6. Bearmera + X-Axis
Status: stable
This page contains all the files and information to use the Bear X axis with the original E3D Hemera.
The Hemera needs a dedicated mount to be used with the Bear X axis. All hardware and printed parts needed are available in the Bill of Materials section below.
- BearMera page
7. Bondtech Extruder + X-Axis
Status: stable
This section contains all the files and information to use the Bear X axis with the original Bondtech Prusa Upgrade Extruder MK2(S), MK2.5(S), MK3(S), Mosquito MK2.5(S), Mosquito MK3(S).
The original Bondtech Prusa Upgrade Extruder needs a dedicated Bear X carriage to be used with the Bear X axis. You can find this special Bear X carriage and all hardware/printed parts needed in the Bill of Materials section below.
- Bondtech page
Author
with
Greg Bear
8,773 Reputation
35 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 78
All Time: 78
