Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Phone Will Not Turn On
The phone will not turn on when you press the power button.
The Battery is Not Holding a Charge
If you charge the phone and see the orange/green indicator on, then the problem may lie in the battery.
The Display is Not Functioning
If the battery indicator is working, then the display may not be functioning. If the sounds for the phone were on prior to the phone not turning on, then try calling the device. If the phone rings, then the screen is malfunctioning.
See the link to replace the screen.
Malfunctioning Motherboard
If the two solutions above are unsuccessful, then you have a defective motherboard. Click here to see our guide on how to replace the motherboard.
Broken Screen Replacement
The screen for the phone is broken/cracked.
Front Glass Panel is Shattered
First, take a deep breath and check if your phone is still functional. Unfortunately, the PS LCD capacitive touchscreen is fused together so you will have to replace the entire screen as one piece. These parts can be found at bluphoneparts.
Slow or Unresponsive Screen
It is possible that the chip inside the phone, called the motherboard, could be acting strangely causing the LCD screen to lag. You should first perform a hard reset on the phone and then check if the phone is working properly. Otherwise, it may be a malfunction in the motherboard.
Blurry Picture Quality
Pictures come out blurry and out of focus.
Dirty Camera Lens
Clean off the camera lens with a cloth.
There's Fog in the Camera Lens
If the phone was in a humid environment, then it could have caused the inside of the camera lens to fog up. Place the phone in a bowl of rice for a day to dry the lens out.
Camera Module is Not Working
If the steps above do not work, the camera module is malfunctioning and will need to be replaced.
Distorted or No Audio
The sound quality is fuzzy or you can’t hear anything at all.
Loose Connection
The wiring to the speaker is either not connected or loosely connected.
Broken Speaker
The speaker itself may be damaged and require replacement.
Defective Motherboard
If none of the above solutions work, then the problem most likely lies in the motherboard. Follow this guide to determine how to repair the motherboard.
Will Not Connect To Wi-Fi
The phone will not connect to Wi-Fi.
Before trying to troubleshoot your BLU Energy X Plus problems, try resetting the phone by turning it off and back on.
If restarting your phone does not work, verify that the Wi-Fi you are trying to connect to is working.
If restarting your phone does not work, and you have checked to make sure the Wi-Fi you are trying to connect to is functioning, the component in the phone that deals with connectivity is the motherboard and it will need to be replaced.
Samuel Dornbusch
1 Reputation
0 Guides authored
USF Tampa, Team 2-121, Cagle Spring 2016 Member of USF Tampa, Team 2-121, Cagle Spring 2016
USFT-CAGLE-S16S2G121
4 Members
60 Guides authored
4 Comments
Wen I'm trying 2make a call it keep on saying limit exceeded an I can't make any calls off either of my sim
Paul - Reply Share
I had an Android update come up and said I had to update the current Android system of my phone. Before this update I was able to use my Hotspot on my phone and after I can't even find my icon or any way to turn my Hotspot on. What do I need to do?
Jennifer - Reply Share
I can't be heard at all by the person on the other end when I make calls using the phone itself but when I use whatsapp to call I can be heard clearly. It doesn't seem to be an issue with the speaker if I can be heard on whatsapp so how do I fix why I can't be heard using the phone call feature.
Rashida Francis - Reply Share
have factory rest mine but on displays welcome and light blue colour, i cant proceed, some help at ericksemakula5@gmail.com
erick Semakula - Reply Share
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 39
All Time: 3,633
