Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Cellphone Does Not Power On
The Cellphone does not respond or show any sign of powering on
Faulty Power Adapter
The BLU Tank II has a micro-USB charging port located on the top of the phone. Check to make sure that the charging cable being used is the correct type. If so make sure there are no cracks or bends in the cable and that it is firmly plugged into the wall and the phone.
If the cable is properly inserted, the screen should turn on showing a battery symbol, indicating that the phone is charging. Therefore if it doesn't appear, consider replacing the charging cable.
Dead Battery
If the cable is properly working make sure you let the device charge for at least 24 hours. If the phone powers on but does not hold a charge, then consider replacing the battery.
If the phone still does not power on, you need a battery replacement.
Keyboard/Keys Not Responding
The keys on your keypad do not respond or have a delayed response
Broken/Missing keyboard
If one of the keys in the cellphone keyboard is missing , the whole keyboard should be replaced using the keyboard replacement guide.
If this is not the case, use the keyboard replacement guide to make sure that the rubber is not broken or fractured on the bottom of the keys.
Frozen Motherboard/Screen
If the Cellphone is freezing or has a delayed response, turn off the cell phone for 5 minutes and then turn it back on.
Damaged Motherboard
If the Cellphone is still freezing and has a delayed response after being restarted, this could be a sign of a damaged motherboard. This can occur if the phone was exposed to water or dropped/damaged. In this case, consider purchasing a new phone.
Problems Taking Pictures
The picture taken by the camera is blurry and is not clear
Dirty/Scratched protector lens
Check the protector lens, if the lens is dirty, clean it with a lens cleaning solution or microfiber cleaning cloth. If the lens is scratched, [invalid guide link]
Damaged camera lens
If there are no issues with the protector lens, the issue might be due to the camera lens being damaged or dirty. Try wiping the lens with a static free micro fiber cloth or lens cleaner. If the issue persists, consider a motherboard replacement.
Not Enough Memory
If there is no recognizable micro SD card in the phone or not enough storage space on the card, you will receive a 'Not Enough Memory' error when taking photos. First, check if there is an micro SD card in the phone. If not, insert a memory card.
If there is an micro SD card in the phone make sure that it is inserted the correct way. On the phone, check whether the micro SD card's storage is full. If it is full, either delete unwanted photos/videos/music or insert a new micro SD card. Otherwise, if the phone does not recognize the micro SD card, consider replacing it.
Problems with the Screen
The screen is scratched/damaged
Scratched Screen
Remove the face plate to see if the scratch is on the outer screen of the cellphone.
Damaged Screen
If the inner screen is damaged , you might consider [invalid guide link] Else, you may have to purchase a replacement phone.
Author
with
Abdullah ALjuhani
101 Reputation
0 Guides authored
IUPUI, Team 5-5, Wilson Spring 2016 Member of IUPUI, Team 5-5, Wilson Spring 2016
IUPUI-WILSON-S16S5G5
3 Members
0 Guides authored
2 Comments
after taking photo, phone indicates not enough memory
darlaharber - Reply Share
when i plug it into a computer, it wont show up in the file area. even when i switch it to mass storage.
Dank_Tank - Reply Share
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 25
All Time: 2,369
