Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
The Phone Does not turn on.
Power button
The device does not respond to the power button being pressed therefore the power button assembly is in need of replacing.
Faulty Battery
if the phone does not turn on and then there is power being sent to it can it be the battery? maybe it is time to change it out a replacement for the battery is needed.
Defective charger
The charger that is being used is not from the manufacturer so it does not work on the phone. replacing charger with original equipment manufacturer is needed
screen display unresponsive
Lcd Digitizer
When the touchscreen on your smartphone becomes unresponsive it is time to replace the LCD digitizer
Unwanted aplications
sometimes when you have unwanted apps or software it can kill the memory on your phone making it unresponsive you can do things like clearing the ram
Rear facing camera
Replace Rear facing camera
if the camera does not seem to work maybe it is time to replace the camera due to it failed one
Software
the front camera does not respond because there are applications running on the background making the camera run.
Firmware
the camera does not want to respond so it may need a reboot in order for the firmware to reset itself.
Battery
Replacement of battery
Noticing the battery does not hold a charge the charge goes from 100 to suddenly nothing replacing the battery is a solution
Applications
there are apps the kill your battery life drastically making sure for this you can go to your settings and view what is killing your battery the most
Firmware
when installing new firmware update make sure there are improvements sometimes it can kill the battery also so re-installing previous firmware is your answer.
Charging Port
"Port assembly"
The device does not want to charge you can open the device and check the port assembly if need of replacing
"Connector/Charger"
Check the connector of the charger itself
"Connector/Charger pins"
check the pins of both the charger and the port for bad connect maybe moving the charger it begins to charge in a certain way
Author
with
Alan Rodriguez
311 Reputation
2 Guides authored
Gateway, Team S1-G3, Luster Fall 2018 Member of Gateway, Team S1-G3, Luster Fall 2018
GCC-LUSTER-F18S1G3
4 Members
48 Guides authored
2 Comments
the bettry turns 100 to 0 ….. i have tried to change the bettry but nothing happened its the same what should i do to fix it pleas tell me
Shahed Mahmud - Reply Share
BLU grandm2 it's not touching one side propaly
Evanston - Reply Share
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 25
All Time: 1,702
