Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Phone won’t power on:
When power button is pressed, the phone does not power on and the screen remains dark.
Hard reset
Take the battery out of the back of the phone and re install the battery after 10 seconds
Not Adequately Charged
Plug the phone into the charger for a few hours and wait. Then try to repower the phone.
Faulty Power Cord
Find or purchase a new cord and charging source. Plug in the phone as if you are trying to charge it and attempt to power on the phone.
Battery
Remove the battery from the phone. Purchase and install a new battery. Attempt to power on phone.
Motherboard
If after trying the previous steps, nothing works, you will need to replace the motherboard because it may have failed or wires have been worn down and torn.
Touch screen is not working:
The touch screen is unresponsive to my touch, or does not turn on at all.
Screen is unresponsive to touch
Here are several possible reasons for a non-working screen, first make sure to use just your bare fingers to try and operate the screen. Wearing gloves may cause the screen to not register your touch. The temperature of your fingers or the weather outside could cause the screen to be unresponsive. Bring the phone inside and let sit for a while before trying again. If screen continues to be unresponsive a replacement may be needed.
Broken screen
If your screen is cracked or broken this can cause the screen to be unable to read your touch due to internally damaged components. A replacement screen may be needed.
Taking blurry pictures:
Pictures come out blurry or foggy.
Dirty Camera Lens
Clean off camera lens with a microfiber cloth.
Fog in lens
Phone was left in a humid environment which would cause fog to develop in camera lenses. Put the phone in a bowl of white rice for a few hours and check process of the phone after a few hours. If the rice does not work, you will need to replace the camera
Camera not working
If all else fails and none of the other steps work, you will need to replace the camera.
Phone will not charge:
Phone will not turn on or charge properly.
Broken Charging Port
Charging port has loose pins and needs repair.
Battery Problem
If your battery life is small and you find yourself plugging it into the charger very often. It is possible that the phone is not charging because the battery needs to be replaced.
No sound coming from phone speaker:
Phone speaker will not play sound or sounds fuzzy.
Broken speaker
Speaker may be blown or broken and need replacement.
Loose Connection
Wires connected to the speaker may be disconnected or loose.
0 Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 22
All Time: 345
