Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Refrigerator Light does not turn on
No matter what you do, you can't get your refrigerator light to turn on.
Disconnected power supply
Before trying to replace any parts or make any major changes, make sure that your Avanti 308YWT is plugged in to an outlet. If it is plugged in, make sure the outlet you are using is not dead. A simple way to do this is by plugging in a different device and seeing if it operates properly once plugged in.
The refrigerator makes a lot of noise
"Cracking and popping sounds are coming from the refrigerator"
The refrigerator is not level
If the Avanti 308YWT is not leveled, it might experience more noise than expected. To level the refrigerator you can adjust the knob on the front right bottom of the fridge. Twisting it to the level will increase the height on the left side of the right side of the fridge. Twisting the knob to the right will increase the height of the right side of the fridge. You can adjust it until you think the fridge is level. To ensure that the fridge is now level, you can use a carpenters level. Place the level on the fridge and make sure the bubble falls between the two lines on the tube.
The Appliance is not keeping food at the right temperature
" The contents of the refrigerator are either too warm or too cold."
Temperature control set to off
The temperature control can be found on the top right of the refrigerator compartment section. Make sure the knob is not set to 0.
Circuit breaker switch
Check the circuit breaker to see if power is being supplied to the fridge. If the circuit breaker is set to off, the fridge will not run. If it is set to off, change it to on and check if the refrigerator starts running
Not plugged in
make sure the refrigerator is plugged in. If the refrigerator is not plugged, it cannot operate.
The door will not close
"When door is shut, the door opens back up."
If the Avanti 308YWT is not leveled, it might experience more noise than expected. To level the refrigerator you can adjust the knob on the front right bottom of the fridge. Twisting it to the level will increase the height on the left side of the right side of the fridge. Twisting the knob to the right will increase the height of the right side of the fridge. You can adjust it until you think the fridge is level. To ensure that the fridge is now level, you can use a carpenter's level. Place the level on the fridge and make sure the bubble falls between the two lines on the tube.
The refrigerator is leaking
"The bass of the refrigerator is always wet"
The evaporator pan needs cleaning
Sometimes liquid will leak because the evaporator pan is not clean. When cleaning the evaporator pan it's important to make sure the fridge is unplugged. To clean the evaporator pan go to the back of the fridge. You will see a tray that you can lift and pull out at the top of the square cut out at the bottom of the fridge. Simply, take the tray and clean it with soap and water.
Author
with
Seye
398 Reputation
1 Guide authored
USF Tampa, Team 1-38, Donnelly Fall 2014 Member of USF Tampa, Team 1-38, Donnelly Fall 2014
USFT-DONNELLY-F14S1G38
1 Member
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 19
All Time: 2,331
