Student In Progress
This wiki is being worked on by hardworking students.
Audio-Technica ATH-S300BT Audio is Distorted
When playing any type of audio, it sounds weak and it's making up broken muffed sound. Complete the following steps to fix your audio.
Clipping
Most common issues with clipping is when the amplifier voltages reaches its limit. By pushing the amplifier past its limit it loses the voltage to produce the reasonable amount of audio signal. This can be a software or physical issue.
  • For a software issue we suggest you reduce the master volume as well as turn off any audio enhancements. Verify that the headphones and your device connect both support the same high tier codec.
  • Restart the connection by "forget" the device in your Bluetooth setting then reconnect.
  • The speakers diaphragm can be dirty with debris, dust, and hair touching the speaker. To clean this remove the ear pad and use a soft brush or a lens cleaning air blower to clean that area.
Driver Failure
The driver can have two common failures which are cause by the physical speaker itself or the software. Listening at a higher volume than usual can tear or melt the diaphragm and even the voice coil inside the driver.
  • Check for any broken internal modules in the affected ear cup. Remove the ear pad, look for any solder parts that may look broken. You'll need to solder the wires that seem to have disconnected.
  • Audio can drop and reject pairing. If this happens hold the power button until the indicator light turns off completely, then turn on the headphones and reconnect the pair as a new device.
Battery Issues
When you come across an issue with the battery it's mostly due to rapid draining and overheating.
  • For any battery draining issue avoid any fast charging adapters because this can push excessive voltage which generates heat. Change the adapter to a low output adapter instead.
  • If your ear cup or charging port feels hot to touch, disconnect the power cable immediately to prevent any more battery issues. An old battery can be the issue, with that being said you should replace the battery.
Speaker Failure
Common speaker failure is caused by a dirty speaker or physical internal damage.
  • Check the speaker for any debris such as dirt, dust or earwax these can cause the audio be off especially at lower frequency. Clean the speaker with a microfiber cloth.
  • Overdriving the headphones with high volume can cause the speakers to be damage or blown out. Blown out speakers can be repaired, so you'll need to replace the speaker itself.
  • Cracks and water damage can cause the speaker to cease functioning all together. In this case, you must go and replace your headphones.
Nathan Padron
202 Reputation
0 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 41
All Time: 60
