Student In Progress
This wiki is being worked on by hardworking students.
Asus Zenbook 14 UX425JA Overheating
When using the Asus Zenbook 14 UX425JA, internal components generate excessive heat, possibly causing system slowdown
Software Overloaded
Computers generate heat by processing, so if a computer has many active programs, it may overheat. Processing speed is slowed to prevent excessive heat damaging the computer.
- To remedy this, first close browser tabs and applications no longer in use.
- Use the keyboard shortcut Ctrl + Alt + Esc to open the task manager, which displays all processing tasks the computer is performing. By default, tasks towards the top of this list will be the most demanding.
- Working down the list, select unnecessary tasks and click the “End task” option in the top right, easing your computer’s workload and preventing it generating excessive heat.
Fan or Vents Obstructed by Debris
Computers use fans to blow hot air away from internal components. This hot air is usually pushed out through vents, if it cannot be removed the computer may overheat. In most laptops, vents are located on the underside of the device. To dispel heat properly there needs to be a slight gap between the bottom of the laptop and the surface it sits on.
- First ensure your laptop is placed on a hard surface. If the device is sitting on an impressionable surface such as your lap, a pillow, or a blanket, there may not be any gap between the vents and the surface, trapping all the hot air.
- If the laptop overheats when placed on a hard surface, the vents may be clogged by dust or debris. Spraying compressed air into the vents can help moderately, but opening the laptop by unscrewing and removing the back cover allows for a more thorough cleaning of the fans and channels where air should flow.
Fan Failure
Fans inside of computers circulate air throughout the device and expel hot air through vents. If a fan does not operate properly, heat generated by the computer continues to build up inside, causing overheating.
- If you cannot hear a fan when your laptop is hot, or if the fan is making unusual noises such as grinding or ticking, you should consider replacing your laptop’s fan using this guide.
0 Comments
