Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
WiFi will not connect
The phone does not connect to the WiFi or drops the connection unexpectedly.
WiFi may be faulty
Check the WiFi router to verify that it is working properly. Try connecting another device. If the WiFi is not working properly, contact your provider.
Device WiFi may be turned off
Got to Settings -> WiFi and verify that WiFi is turned on. You may need to go tap on the advanced settings and select "Keep WiFi on during sleep."
An error may have occurred with WiFi reception
Go to Settings -> WiFi. Turn the WiFi off and then back on.
An error may have occurred with the WiFi network
Go to Settings -> WiFi and find the desired network. Tap and hold on the network and tap "Forget network." Now reconnect to the network.
An error may have occurred with the device
Reboot your phone. To do so, hold the power button and press "Restart."
The device may require an update
To update the firmware, go to Settings -> About -> System update and tap "Check update."
The device may have encountered a major problem
If nothing else works, you may have to perform a factory reset.
WARNING: a reset will remove all data, apps, and personal information.
Go to Settings -> Backup & reset -> Factory data reset and tap "Reset phone."
Cellular data does not connect
Phone does not connect to carrier service
Your data provider may not be providing service
Contact your mobile provider to ensure that they are providing service to your SIM card.
Firmware is not up to date
Data may connect after using airplane mode
Turn your phone off and remove the SIM card. To remove the SIM card, open the compartment on the left side of the device and take it out. Return the SIM card and turn your phone back on. Turn on Airplane mode, wait 3 seconds, and turn Airplane mode back off. Wait for data reconnection.
Camera shutter sound does not stop
After taking a picture, the shutter sound continues to play
An error may have occurred with the camera application
To manually close the camera application, tap the multiview button on the bottom right of the screen and slide the camera off the screen.
Camera sound is the issue
Launch the camera app, go to the gear icon in the upper-left corner, and disable “Camera Sound.”
Pictures do not save to microSD card
The phone does not save pictures to a microSD card
MicroSD card may not be properly installed
Open the compartment on the side of the device and remove the microSD card. Check the orientation and put it back in.
Settings may not be set to save to microSD
Make sure that the camera settings are saving images to the card. This can be done by pressing the gear icon in the camera app, selecting “Save to”, and then selecting your microSD card.
There may be an error with the device
If the card still does not register, save all data on your phone and perform a factory reset of your device.
MicroSD card may be incompatible
If none of these solutions work, your microSD card may be incompatible with your device, and you will need to buy another one.
Phone does not recognize SIM card
The phone does not recognize when a sim card is put in the phone
The SIM card may be improperly aligned
Open the compartment on the left side of the device. Remove the SIM card and re-insert it.
The SIM card may be dirty
Remove the SIM card (see above). Clean the SIM card with an electronics cleaner, preferably something higher in alcohol content so no residue will get in the way.
The SIM card’s pins might also be bent. Try gently lifting them up with a toothpick or a small tool, as they are very fragile. Only do this if the above does not work.
The carrier may not be providing service
Ensure that all bills have been paid and check with your wireless carrier.
Seth Hayes
51 Reputation
0 Guides authored
1 Comment
Sometimes you may have connectivity issues with the Wifi because of the router! You can unplug it for 15-20 seconds then plug it back in and turn it on, and try to connect your device again.
Bianca Ceaser - Reply Share
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 15
All Time: 1,495
