Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Computer Dies Easily
Computer powers down quickly after charging.
Faulty Battery
If the computer turns off after disconnection of the adapter, the battery is most likely faulty. A reason for this may be due to the declined use of battery supporters. Despite the Li-on battery for the Asus computer, the battery is “self-discharge” and damages the battery memory.
To fix this:
Remove the Li-ion battery and directly use power supply to charge the laptop. Remove all portable external devices, such as USB, memory card, internet cable, HDMI, and CD-ROM. Then expand partition of hard drive or memory card.
ASUS Battery Support
Faulty Adapter Cable
If the adapter is plugged in and the computer still dies, this may indicate an adapter cable problem. To fix this:
Check whether connector of adapter is loose or not and check whether there is any damage on the adapter cable
Adapter Cable Support
Audibility issues
No sound when audio is played through the computer or volume bar is frozen.
Asus X54C-RB92 has audibility issues where the device loses its function of controlling the speaker volume.
Error in Device Manager
Open Start, enter Device Manager, and select it from the list of results. Under Sound, video, and game controllers, select and open your sound card . Select the Driver tab, and select Update Driver. If Windows doesn't find a new driver, look for one on the ASUS website and follow the instructions.
If those steps didn't work, try uninstalling your audio driver : open Device Manager, right-click (or tap and hold) the audio driver, and select Uninstall. Restart your device and Windows will attempt to reinstall the driver.
If that didn't work, try using the generic audio driver that comes with Windows as following: In Device Manager, right-click (or tap and hold) your audio driver > Update driver software... > Browse my computer for driver software > Let me pick from a list of device drivers on my computer, select High Definition Audio Device, select Next, and follow the instructions to install it.
Wrong Audio Enhancement Setting
Go to Start, enter Sound, and select Sound Control Panel from the list of results. On the Playback tab, right-click (or tap and hold) the Default Device and select Properties. On the Enhancements tab, select the Disable all enhancements check box and try to play your audio device. If that doesn't work, select Cancel and, on the Playback tab, select another default device (if you have one). Select the Disable all enhancements check box, and try to play audio again. Do this for each default device.
ASUS Audio Enhancement Support
No Wi-Fi connection
Wi-Fi stopped working after the first update and no longer connects to public or home Wi-Fi.
Malfunctioning Wi-Fi Card
To fix this:
Turn off your router for 1 minute and turn it back on.
Wi-Fi Card Support
Loose Ethernet Cable Port
To fix this:
Connect the ethernet cable to the laptop. If the ethernet cable is securely placed into the port and the internet is still not functioning properly, a new ethernet cable may be needed.
Wireless Function Activation
Make sure the wireless function is activated on the laptop so internet may be utilized.
To fix this:
Make sure whether the wireless function is activated. Turn on/off wireless function by hotkey Fn + F2
Check whether the wireless network device in Device Manager is abnormal. Select Start, click on the Control Panel and select the Device Manager icon and check whether the Internet Interface card appears with an exclamation mark.
Enter [Network and Sharing Center] for troubleshooting. No exclamation mark on Device Manager means normal working of the Internet Interface card. It might be caused by system setting or other internet facilities. Select Start, click on the Control Panel and select the Network and Sharing Center icon to check basic network information
[Start] -> [Control Panel] -> [ Network and Sharing Center] -> check basic network information
If there is either exclamation mark or 'X' , you can click and conduct troubleshooting for Internet issue in Windows.
ASUS Wifi Support
Keyboard and touchpads are unresponsive
Asus X54C-RB92 Hotkeys and touch-pad are not working and inoperative
Malfunctioning hotkeys
If the hotkeys are not working it is best to install the latest Driver.
To install new Driver:
Go to the Control Panel and click on Device Manager. Select Keyboards in the new window to open the list of keyboards below it, and right-click on the listed keyboard and click Properties. In the new window, click the Driver tab and then click Uninstall. When the Driver has finished uninstalling, click OK and close any opened windows. Reboot the computer. After the laptop has rebooted the keyboard Driver should reinstall by itself.
There is also a Asus support page that includes some alternative ways to fixing more specific problems.
https://www.asus.com/support/faq/1015071
Issues with touchpad
The touchpad is inoperative and fails to communicate with the laptop.
To fix this:
This will require new system updates for the drivers as well as tools to their latest versions. These updates include ATK Package, Smart Gesture, USB Charger+, Audio, Bluetooth, Wireless LAN, LAN, Graphics, Card Reader. As well as some other drivers and BIOS updates. All of these Updates and how to install them are included in this link below.
Drive will not read discs
DVD-Writer optical drive is unable to read or write the discs.
Optical drive crashes while loading discs
To fix this:
Update the BIOS to the latest version and try again. If updating the BIOS does not help, try better quality discs and try again. If the problem still exists, contact your local service center and ask an engineer for assistance.
Issues reading disc after updating Windows software
To fix this:
If the external drive is missing from the Device Manager, look for an entry called [Initio Combo Device Class]. Click on the “>” next to it and right-click on Initio Default Controller and click Disable to turn it off. Right-click on it again and click Properties, then click on the Driver tab that pops up and click on Uninstall to uninstall the drivers. Then unplug the external drive from the USB ports and fully shut down your computer. With the computer powered off, plug in the external drive to the USB ports. Then, restart the computer.
Issues with the built-in camera or webcam
The camera is reported in use by another program, and the webcam software will not open.
Built-in camera could not be found
To fix this:
Press Windows key + C to show the Charms bar, and type “Troubleshooting” and click Troubleshooting under Settings. Type “Hardware Troubleshooter” in the search option, and click on Hardware Troubleshooter to run the troubleshooter. If the issue still persists, install the latest Driver from the Asus website.
Pre-installed webcam software will not open
To fix this:
Click on the Start menu, then click on the Asus folder and select the LifeFrame icon. If that does not work, hold down the fn button (next to the control button) and press the V button.
Julia Huang
355 Reputation
3 Guides authored
Baylor, Team S1-G3, Johnson Fall 2017 Member of Baylor, Team S1-G3, Johnson Fall 2017
BU-JOHNSON-F17S1G3
2 Members
36 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 33
All Time: 1,533
