Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Wifi Connection Issues
Can not connect to Wifi or getting poor connection when connected.
Wifi Chip Failure
Changes to your network connection. Experiencing poor wifi connection or no wifi connection. Test the ping by opening the Windows command prompt and typing “ping 127.0.0.1” and press enter. If there is no response the card may be faulty and in need of replacement.
Display
Screen is broken or cracked.
Screen is Disabled
Screen may be disabled and not broken. To re enable the screen hold down the Fn button and at the same time press the F2 button. Make sure the laptop is charged and fully booted before pressing the buttons.
If the fn and f2 buttons yield no results the computer may be in projector mode. To leave projector mode hold down the windows key and then push the "P" button twice. This will put it back into computer only.
Broken screen
Screen may be cracked or shattered. Light may or may not come from screen, and no images can be seen. Screen is in need of replacement.
Overheating
Computer shuts off randomly during usage.
Dust clogging air flow
It is common for dust to accumulate in the air vents and in the fan. By using compressed air carefully clean the vents and fan.
Broken fan
If after cleaning the vents and fans you are still experiencing overheating, than the fan my be broken. Replace the fan making sure the new fan is compatible with the VivoBook S200E.
Battery
Battery holds little to no charge.
Short battery life
Battery does not last longer than 2 hours on full charge. Caused by exposure to cold weather, continually charging, and/or around 2 years of common usage.
Storage Space
Less than sufficient storage for files.
Replace Hard Drive
Replace the hard drive with a larger hard drive.
Justin Ogihara
31,629 Reputation
52 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 37
All Time: 647
