Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Computer is slow
The computer runs very slowly when handling multiple programs, or it takes a long time to execute programs.
Too Many Programs
When there are a lot of downloaded programs on your device, they can take up space and slow your laptop down. It can be difficult to know if some of these programs run in the background without user knowledge, and this can cause further slowing. Find programs that you do not use and uninstall them from your device.
Dust Accumalation
Over time dust can accumulate in the hardware which can cause overheating and sluggish performance. Flip the computer over and notice the vents on the bottom and sides. Proceed to vacuum dust out of the computer through these vents.
Old or Corrupt RAM
If your computer crashes during normal operation, crashes during memory intensive tasks, or beeps and will not boot up, this means you may have bad RAM or that you do not have enough RAM. See guide to replacing RAM for your device.
Old or Corrupt Hard Drive
The Seagate Momentus hard drive used in this computer is known to wear down after years of use. Errors/corruption can occur when the user shuts off the computer by use of the power button instead of initiating the shutdown sequence through the operating system. To resolve this issue, get a Windows DVD for the version that you have. Please note that the specific version does not matter, only that it is for Windows XP, Vista, 7, or 8. Boot to the DVD, and choose “Repair your computer,” then click next. On this screen, pick “Startup Repair” and let it run. After this, your Asus UL80VT should boot correctly. If your computer does not boot correctly and still has issues, you may need to replace your hard drive. See guide for replacing hard drive.
Battery Does Not Hold A Charge
The battery does not hold a charge or the battery life does not last long.
Faulty Power Adapter
Ensure the power adapter is plugged in and the charge light is on. If the light is not on, and the adapter is plugged in, the adapter is faulty. Consider purchasing a replacement adapter.
Faulty Battery
If the laptop only powers up when the power adapter is plugged in, or the battery is not holding a sufficient charge, then the battery is faulty. Fortunately, the battery is easy to replace, follow the guide provided for proper instructions.
Distorted Audio From Audio Jacks
When using the audio jack, the sound is distorted due to a internal metal contacts spreading.
Faulty Audio Jack
With repeated use, the contacts within the audio jacks spread causing a weak connection. Test audio through the computer speakers, then test it using headphones. If the audio is only distorted while listening via headphones, the audio jack or the headphones themselves may be faulty. Audio that cuts in and out is often a sign of a loose/faulty audio jack, so make sure the audio jack is fully inserted in the computer. These inputs/outputs need to be replaced, see guide to replacing audio jacks.
Poor Wireless Connection, Computer Still Running Poorly, etc.
After trying the solutions above, if the device still has issues try these solutions.
Out of Date Operating System
As the device gets older, the software can become outdated. Updating the operating system ensures support for the latest internet technologies. Follow the instruction: https://www.microsoft.com/en-us/software...
Faulty Motherboard
If you’ve tried everything above and things are still not functioning properly there could possibly be component failure and you should replace the motherboard. Motherboard issues can be caused by dust or other substances ruining the electrical components. See the guide for replacing the motherboard.
Author
with
Daniel Shea
63 Reputation
0 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 538
