Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Asus UL30VT-A1 Troubleshooting
Released March 2010, model number UL30V.
Computer Will Not Power On
The laptop will make a flickering light or not power on at all.
Defective Battery
First, check if the battery is dead by plugging in the laptop charger. While plugged in, if the laptop turns on but the battery in not charging, then the battery is defective. Check battery replacement guide for the Asus UL30VT-A1. If the laptop still will not boot up after checking the battery then try a different AC adapter that has the same voltage. Use this battery replacement guide.
Problem may lie in the Motherboard
Lastly, if you press the power on button and the LED light is flickering, try connecting an external monitor and see if you get any display. If any of these options do not work the problem may lie in the motherboard.
Overheating
The overheating is occurred by using the computer or laptop
Dirty air vents
The first thing you’ll want to do is find where the heat is coming from the laptop . Laptop need a way to expel the hot air created by their components, if there’s no air flow this means no heat, transfer, so in this case first you should be figuring out where all air vents from the laptop is located at. Most laptops they have vents from the bottoms in order from them to let the computer start working.
Faulty Fan
The first clear sign of a damaged fan is if it’s making weird noises. The number of rotations your fan can withstand is of severe importance. You may want to inspect the fan and make sure it is physically damaged. In case the fan is not effectively cooling the laptop, replace it. Use this guide.
Distorted Image
The cost on many laptops screen cost is about $80-$100 and a couple hours of your time. It’s better to replace your computer parts as you learn. It is a good investment to repair something simple as your screen. You will have to make sure that the screen has to be replaced and not other parts, such as your power connect or power on button.
Broken Frame or Screen
You can check clearly that your need a screen replacement if your screen is broken but if your not sure because there is no cracks then I would recommend you to connect it to your desktop monitor or television to see if the image appears clearly. In some cases the screws are not a problem and you can easily removed the frame. If that’s not the case then you will have to get the right screws and you can probably find them on Amazon, Ebay, or another replacement part site. Replace screen guide.
Constant Crashing, Slow, Not Recognizing Storage
The first thing you will want to do is check if the laptop is registering your drive. If not you will need to open up your laptop. If so backup all your data. Remember to always power off your device before doing any hands on work.
Damaged Power/Motherboard Connectors
Inspect your hard drive to make sure its connectors are properly fastened. You also want to make sure none of the connectors are physically damaged. Remember there are multiple connector running to your motherboard and power supply. In case they are you will want to buy a replacement cable and swap it out.
Damaged Hard Drive
If the cables are not the problem, detach them and inspect your hard drive. Look for any clear signs of damage. If you see clear signs of damage you will need to replace your hard drive. A broken hard drive is the perfect time to upgrade to a newer model. Use this Hard Drive Replacement Guide .
Difficulty Typing
The keyboard keys are not registering when in use. The first thing you want to do is to check which keys are unresponsive. You can open a Word document and check each keys one by one to see if they work.
Faulty Keys
Sticky keys can also be another source why key aren’t working. If you aren’t able to press down on keys look for any damage parts or debris under keys. In order to fix this problem replace key switches. Use this guide.
Author
with
Misael Ramos
236 Reputation
1 Guide authored
Gateway, Team S1-G2, Saknee Spring 2019 Member of Gateway, Team S1-G2, Saknee Spring 2019
GCC-SAKNEE-S19S1G2
5 Members
36 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 18
All Time: 523
