Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Laptop won't turn on
When I press the power button on my computer, nothing happens.
Device needs to be charged
Plug in the power adapter and try to turn on the computer. If your computer turns on while plugged in, the battery needs to be charged for a few hours. If your computer doesn't turn on at all, the battery needs to be replaced.
Faulty power adapter
If your computer isn't charging, it might be a faulty power adapter. If possible, try a different adapter of the same voltage to see if your computer will power on.
Dead battery
If your device does not turn on at all, even after charging it, you should replace the battery.
Asus K52F-BBR5 Battery Replacement
Computer gets too hot
My computer becomes extremely hot, causing it to slow down
Dust in fan
Sometimes your device may overheat due to dust or other materials stuck in the fan.
Cleaning the inside of your computer
  1. Turn off your computer and unplug it from any electrical outlet.
  2. Open your computer's case.
  3. With compressed air, dust the inside of your computer of computer. Try to remain a few inches away from your device.
  4. To remove the dust from the fan, use compressed air while holding the fan with your finger to keep it from spinning. You can use rubbing alcohol to clean the blade with a cotton swab.
  5. Finally, dust off all the ports on the computer and clean all exterior vents with rubbing alcohol and a cotton swab.
Fan is being blocked
Try to keep the bottom of your device free of any objects, so the laptop can get the air it needs to keep cool.
Black screen
My device's screen is completely black, yet I can still hear sounds.
Screen brightness is too dark
Your brightness could be possibly be turned down all the way, causing your screen to be too dark. You can use FN + F5 or FN + F6 on your keyboard to adjust the brightness.
Startup error
Your screen might be black because of a startup error. This is usually related to the video card or inner programs.
Startup error fix
  1. Remove the battery and adapter from computer.
  2. After a few minutes, insert the battery and adapter.
  3. Make sure the computer is clean and dry. If the computer is in a moist environment it might not startup.
  4. Hold the F2 key and power button at the same time and release at same time to see if it works.
Battery/Charging issues
If the previous methods did not work, it could possibly be related to the battery. In which case, you would need to replace the battery. For assistance on replacing the battery refer to our guide.
Touchpad is not working
My device's touchpad does not respond to any contact
Touchpad is disabled
Sometimes your touchpad may automatically be disabled when an external USB is inserted.
How to enable touchpad
# Control Panel > Hardware and Sound > Mouse.
  1. Click on ELAN on the top right and click Disable when external USB mouse plug in check box.
  2. Click on OK to finish the configuration
Defective touchpad
If your touchpad does not respond to any contact, you most likely have a damaged touchpad. You can use a mouse as an alternative or have your touchpad replaced.
0 Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 35
All Time: 1,614
