Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Blue Screen of Death
Laptop receives the blue screen of death during usage
Use a System Restore
A system restore can roll your operating system back to a previous state before you started receiving the blue screen of death. To use a system restore in Windows 10, hit the start button and type “system restore.” From here, choose “Reset this PC.” This will give you the option to reset the PC by selecting the files you wish to keep, and then completely reinstalling Windows 10, or to “Go Back to an Earlier Build” which could revert your PC back to an earlier state before it started receiving the blue screen of death.
Update Drivers
Updating the drivers for your hardware can prevent bugs and crashes. To install the latest drivers, navigate to your Control Panel, and type into the “Search Control Panel” tab “Drivers.” This will bring up an option to update drivers. From here, you can view all devices, and whether or not there is an available update to that device’s drivers.
Scan for Malware
Malware and viruses can sometimes infect certain areas of your computer and cause blue screens of death. Use your specific antivirus software and run a full scan of your computer to search for any malicious software.
Laptop randomly turns itself off
Laptop randomly shuts down during use
Overheating issue
If your computer is turning itself off during use, this could be caused by the computer overheating. Overheating can be caused by dust and other materials clogging up the fans and vents in your computer. To fix this issue, use a compressed air duster to clean out the fans and vents. Simply spray into the vents and fans, dislodging any materials stuck in these areas.
Screen will not turn on
Screen will not turn on when opening or turning on laptop
Weak Battery
To check if the battery is the source of the issue, remove the battery if possible. Next, plug in your AC adapter (charger) to the computer. If the computer boots up normally while plugged in, then the battery will need to be replaced.
Display Issue
Connect an external monitor to your computer to check if your laptop display is the reason your screen is not turning on. If the monitor displays normally, check your display settings within the settings of Windows to ensure that everything looks normal. If so, you may have to replace the built-in screen on your laptop.
Audio sounds distorted
Audio does not sound normal while using the laptop
Update Drivers
Sometimes outdated drivers can distort the audio on your laptop. To install the latest drivers, navigate to your Control Panel, and type into the “Search Control Panel” tab “Drivers.” This will bring up an option to update drivers. From here, update all drivers that have to do with audio, sound, etc.
Replace Speakers or Audio Jack
To figure out whether the distorted audio is coming from your audio jack or your laptop speakers, plug in headphones through the audio jack and test the sound. If the audio is distorted, then you may need to replace your audio jack. If the sound is normal when listening with headphones, the speakers on your laptop may need to be replaced.
Laptop is frozen and unresponsive
Laptop has frozen and the screen, keyboard, and mouse are unresponsive
Restart your Laptop
To restart your laptop when it is frozen, simply hold the power button for a few seconds until the display turns black and begins to restart the booting process.
Laptop Overheated
An overheating issue could result in the computer freezing up and becoming unresponsive. To fix this, use a compressed air duster to clean out the fans and vents. Simply spray into the vents and fans, dislodging any materials stuck in these areas.
Frozen Application
If the application you are currently using is frozen, hold down ALT-CTRL-ESC together to bring up the task manager. From here, simply close the application that is causing the issue by clicking on it, and then selecting the End Task option.
Michael Tree
157 Reputation
0 Guides authored
Gateway, Team 1-4, Kuhn Fall 2015 Member of Gateway, Team 1-4, Kuhn Fall 2015
GCC-KUHN-F15S1G4
1 Member
0 Guides authored
6 Comments
How do we change harddrive if it is soldered on the motherboard for computer which doesn;t boot anymore?
Gdencio - Reply Share
I have found that smetime the asus X205TA fails to boot. The light indicator is on which suggests that it is charged. If I hold in the power key for about 30 second until the light goes off I can then press the power key again and it boots
donna kim - Reply Share
Hi my Asus EeeBook is frozen, will switch on and load the log on screen but then no mouse or key board life. In the bottom right hand corner there is an icon which looks like a screen with a red X at the bottom. Can anyone help ? Thank you in advance
Zoe woodhead - Reply Share
Where are the fans Located? My asus has now become overly easy to overheat and just turning it on will make it overheat. How do i fix this! I have not noticed that my laptop was overheating until i found out my laptop keyboard started melting abit. This also affected my audio and speakers. My speakers now do not work.
VoteAlt - Reply Share
Hello… my asus X205TA says no audio output device is installed… what can I do please?
ojobabatunde979 - Reply Share
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 42
All Time: 3,923
