Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Wi-Fi not working or no Wi-Fi connection option
The Asus Chromebook will not connect to the internet, or if the laptop does not show any Wi-Fi connection to the user.
Wi-Fi Setting May Be Set To Off
There may be an issue where Asus Chromebook won’t connect to the internet.
  1. From the bottom right toolbar, click on the status area.
  2. The status window will open. In it, click on "Connected to..."Or “Add Connection“
  3. It will then present a list of available networks.
  4. Click on the top network in bold to enable the network.
Wi-Fi Chip Not Installed Correctly in the motherboard
Sometimes when you are using the device, there will be times when the Wi-Fi connection won’t let you use the Wi-Fi or if the Wi-Fi option isn’t there. That Wi-Fi card needs to be replaced with a new one.
Laptop not charging to the fullest
The Laptop battery status will stay and not charge fully, or not charge at all.
AC Adapter May have Gone bad
From time to time, the AC adapter can go bad. If it takes a longer time than usual to charge, or if there is no power from the AC Adapter, It’s time to get a new one.
The laptop Battery may be faulty
The laptop can last a while but it won’t be a lifetime. If you notice that the battery won’t charge or if the battery is draining rapidly. It’s time for a replacement.
Speaker not functioning or not hearing audio
The speaker on the device will not work when trying to receive audio.
The Audio Was Set To Another Speaker In The System
Make sure that the audio is set to its standard settings. For example, make sure it’s not connected to any Bluetooth devices or headphones.
For Bluetooth
  1. To Check, go to the status page on the bottom right
  2. The status page should bring up a menu toolbox, Then click on Bluetooth and disconnect them from there.
For Speakers
  1. Go to the status page on the bottom right.
  2. Open the status page and click on the headphone icon.
  3. Make sure the audio is changed to “Speakers“
The Laptop Speaker Is Turn Off On The Setting
Your device may have its audio turned off. To check if the audio is off, make sure you go to set it to the right audio.
  1. By doing so go to the bottom right of the home screen and click on the status page
  2. Then In the Audio Icon that has a Slider to control, move the slider to see if audio is coming out or, click on the icon to see if the audio is off.
The speaker on the laptop may be faulty
The speaker inside the laptop may be loose or glitching/static. If so, a new speaker for the device is needed for a replacement.
The keyboard not typing and no LED keyboard light
The keyboard will not function while using it and LED lights will not show up, The Keyboard might be stuck while using.
The Keyboard May Be Disconnect From The Device
If no LED lights show or if it’s not responding to the device, it is time for a keyboard replacement.
Touchpad/Trackpad does not respond
The Touchpad/trackpad may not be responsive when being used.
The touchpad ribbon cable is loose
The laptop ribbon cable may be damaged or loose and need to be replaced or put back into place.
Author
with
Zahid Enriquez
543 Reputation
4 Guides authored
Gateway, Team 1-2, Saknee Spring 2022 Member of Gateway, Team 1-2, Saknee Spring 2022
GCC-SAKNEE-S22S1G2
4 Members
60 Guides authored
1 Comment
It is already looking good.
Asifiwe Murhula - Reply Share
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 17
All Time: 797
