Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Headset Will Not Power On or Dies Quickly.
The headset isn’t coming on at all or lasts for a shorter time than the product design.
Battery Issue
Make sure the headset has been charged for the appropriate time using the charger provided with the headset. If the headset will not power on at all then a faulty battery could be a possible cause. If the headset powers on but dies faster than the company advertises then a faulty battery is most likely the cause.
Headset Does Not Fit on Head Correctly
The headset isn't fitting correctly or won't stay on your head.
Doesn't Fit
These headsets are adjustable to fit a variety of head sizes. First check to see if you have adjusted the headset in the appropriate way to fit your head. If that doesn't work then the headset might be structurally malfunctional or broken. This can be fixed by correctly reconstructing the frame or replacing it.
Broken Frame
If the frame of your headset has separated or snapped due to physical damage then a replacement part is needed.
Microphone Not Picking Up Your Voice
The microphone is not recording or reading your voice.
Broken Microphone
First make sure that the microphone is not mute. If the microphone is not mute and the headset is still not picking up your voice your microphone could be broken. If your microphone is broken then the headset will not pick up your voice or it might only pick up your voice sometimes. A common problem is that the firmware needs to be updated. to fix this you will need to go to the Astro Gaming website and update your firmware. If your firmware is updated then you will need to repair your microphone.
Unable To Connect To Wifi
The headset is unable to connect to a wifi setting.
Broken Radio/Transmitter
Double check that the wifi option is turned on. If the wifi option is active and working and still not connecting to wifi, double check the wireless connectivity of the source of wifi nearby and make sure that it is within range of the A50’s capability, which is up to 25 feet. If after checking the activity of the wifi option and the connectivity of the wifi, you still cannot connect to wifi, the issue is a broken transmitter, which would need to be replaced or repaired.
Unable to Hear Anything or Hearing Static
The sound coming out of the headset is not expected.
Broken/Blown Speaker
If no sound is coming out of the headset speakers (both or only one) or is all you are hearing is static; first make sure correct that headset is on or that you are connected to radio transmitter. If headset is on and connection indeed is made and to transmitter then the speaker will need to be replaced or repaired.
Author
with
Sovanna Rice
113 Reputation
0 Guides authored
UMass Dartmouth, Team 2-5, Shastany Fall 2015 Member of UMass Dartmouth, Team 2-5, Shastany Fall 2015
UMASSD-SHASTANY-F15S2G5
4 Members
48 Guides authored
25 Comments
how do you fix a faulty battery? my headset just wont turn on at all
Andreya Deluca - Reply Share
i have a problem with my head set today i was playing and the head set was on low battery and it died so i charged them aftern that it wont turn on
Mohammed Alfattan - Reply Share
So how do you repair the microphone? Firmware is updated and everything. Still my mic will not work at all. Please help!
Jake Duffee - Reply Share
Bro. Did u know how ?
hafed_1234_koo0oo - Reply Share
My head set won’t turn on at all I tryed the hard reset with holding the game button and equalizer won’t turn on tryed hooking it to the pc still won’t turn on wen I look on my Xbox it says it’s all plugged in and working but no power light please help
Shane - Reply Share
Past 24 Hours: 10
Past 7 Days: 62
Past 30 Days: 244
All Time: 51,182
