Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
No sound coming through the headset
The headset plays no sound.
Not plugged in completely
Check to make sure headset cable is plugged in completely into both the headset and mixamp.
Mute button is on
Check the mixamp cable to see if your mute button is on. To check, look for a red strip on the Quick Disconnect cable. If it you cannot see it, then the volume is muted. To fix this, lightly push the switch off so that the red strip is visible.
Sound only plays on one side
Audio only comes out of one side of headset.
Wrong cable
Make sure the A40 Console Cable is plugged in correctly. The mute switch side should be connected to the headset and the other end to the mixamp.
Static/crackle noise
Microphone generates a static and/or crackle noise along with audio.
Controller cable faulty
Do you have to move controller cable around in order to get audio connection? If yes, then the issue is with the controller cable.
Loose connections and cables
Sometimes, the cables and connections may be loose. Make sure all your cables are securely plugged in place.
Defective Mixamp
Disconnect all cables from headset and mixamp, then plug your mixamp into PC and use the sound recorder application that comes with Windows OS. Record and save an audio clip onto your desktop or hard drive. Playback the audio to check if issue still exists. If yes, then the underlying issue is with the microphone or headset. If no, then the issue is with the mixamp only.
Issues with Microphone
Microphone does not work properly after Realtek Driver installation
USB drivers need updating
Often times the Realtek driver correlates with the USB drivers so if you have updated your Realtek drivers recently, it might have affected the USB drivers. Simply update your USB drivers at this point and see if it works. To update USB drivers, go to Asto Firmware updates page and install following the instructions.
Audio jack on PC disabled
If your microphone issue is not related to the Realtek driver and USB firmware updates, check to see if the microphone is plugged in completely into your headset and PC. Make sure that the microphone is enabled, and that the output level is not set to minimum or muted.
Mixamp not recognized on PC
''Computer unable to recognize mixamp"
Firmware needs updating
Make sure your firmwares are up to date. You can update the firmwares via the Astro Firmware page. If the problem persists, try plugging the USB cables into different ports.
Author
with
Donavan Feliz
444 Reputation
2 Guides authored
Cal Poly, Team 20-18, Maness Winter 2015 Member of Cal Poly, Team 20-18, Maness Winter 2015
CPSU-MANESS-W15S20G18
4 Members
60 Guides authored
2 Comments
Tenho problemas com o Microfone tenho q ficar batendo ou rodando a peça do Microfone para funcionar, qualquer movimento para de funcionar. Por favor me ajudem não faço ideia da origem do problema, se é o encaixe ou a peça do microfone.
marioporfirio - Reply Share
So I have my mic setup to all audio on my ps4 and it takes away the sound from my tv as is it works but I can’t hear anything and nobody can hear me either
Slick - Reply Share
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 64
All Time: 57,527
