Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Problem connecting to the iTunes Store
When trying to view content, the following error message appears: "There was a problem connecting to the iTunes Store to restore the purchase. Please try again later."
Network not connected
Press the ‘menu’ button until the screen displays all apps. Navigate to settings > network. WiFi is the first option at the top of the page and will cause the TV to search for and display all available networks. Scroll to and select the appropriate network. You may be prompted to enter a password.
The Apple TV cannot find WiFi network
The device cannot find a WiFi network when one should be in range.
Automatic connection failure
If you do not see your network listed, you may use the ‘Other...’ option at the bottom of the list to enter the name of the network manually.
Network information mismatch
If you have correctly entered your network’s name and are still unable to connect, you can restart your wireless router before connecting again. Failing this, go into the network settings by typing 192.168.1.1 into the browser of a computer with access to the network and log in. Make note of the SSID in the router's settings and enter it into the Apple TV's manual connect option.
Remote not responding
Apple TV does not respond to remote commands.
Low Battery
Your remote’s battery may be out of power. Charge the remote with an AC adapter by plugging a lightning cable into the port at the front narrow end of the remote.
Remote is un-paired
Re-pair the remote to the Apple TV by holding it “three inches” from the device and pressing the ‘menu’ and ‘volume up’ buttons simultaneously. You may be asked to set the remote on top of the Apple TV.
Software glitch
Restart the device: unplug the Apple TV’s power cord, wait six seconds, and plug it back in.
Remote app issues
Apple TV does not respond to commands from device with remote app installed.
Device is unpaired
Go to Settings > Remotes and Devices > Remote App and Devices. Check to see if your phone or tablet is listed. If it is not, pair the device. Open the remote app and tap ‘Add a Device.’ On the Apple TV, open ‘Remote App and Devices’ and select the device. Enter the four-digit number provided by the Apple TV into your mobile device.
Device needs to be re-paired
Select the device in Remote App and Devices and choose the 'Forget' option. Then, using the steps above, re-pair the device.
No sound
Sound is not projected.
Auxiliary equipment malfunction
Check your television and/or audio system to ensure that volume is not muted and that the levels are properly configured. Ensure that any fuses/breakers are functioning properly and that cables are fully seated.
Apple TV setting discrepancy
Go to Settings > Video and Audio > Audio Output. Ensure that the television itself is selected.
Wrong audio mode
By clicking ‘Audio Mode’ on the ‘Video and Audio’ settings page, change the option from ‘Auto’ to 16-bit. This may allow audio to play.
Wrong surround sound setting
Try changing the ‘Surround Sound’ option. Cycle through ‘Stereo,’ ‘Dolby Digital 5.1,’ and ‘Best Quality Available.’
HDCP error
When attempting to play content, a black screen appears with the following error message, “HDCP isn’t supported by your HDMI connection. This content requires HDCP for playback.”
Failed HDCP handhsake sequence
Turn off the Apple TV and unplug its power cable. Turn off the television and unplug it as well. Also disconnect the HDMI cable from both devices. Allow everything to sit for 30-60 seconds. Then, reconnect the HDMI cable, and then the TV, and then the Apple TV in that order. Power everything on and see if the message appears when content is played.
Unable to turn on
Power supply failure
If the Apple TV does nothing when the power cord is plugged in (ensure there is electricity), then the device's power supply may be at fault. Look here for instruction on how to replace the power supply.
Author
with
Eric Arnold
386 Reputation
1 Guide authored
3 Comments
the Apple TV 32 GB I have is blanking off Video and Audio after about 10 minutes of use, from a Power On mode. The Video and Audio is blanking out every few seconds and the outage is lasting for a couple of seconds. After a few blanks, I lose both Video and Audio completely and even the buttons on the Remote do nothing although I can see the power light flickering whenever I press any button on the Remote to go back to the home page, or press the glass surface to pause/stop. After a few minutes I will get back the screen.
If I am playing from my MacBook using AirPlay, the streaming is absolutely fine on the MAcBook but the Apple TV would have the blank screen and of course No audio. I have changes the HDMI cables, powered off completely Everything and restarted, and the device does report the HDCP and I even called up the Cable TV technician but the outages continue. I then swapped my old Sony BluRay DVD and although the speed is 30bps the streaming is not causing any issues; only on Apple TV.
Rudy Rana - Reply Share
We just bought our second Apple TV for generation and after 45 months it does not even come on all we see is a blue screen we tried troubleshooting and nothing.
Lorna J.Burns- Bridges - Reply Share
Has anyone ever got an Apple TV or TV+ to work on an universal remote? And if so, may I ask how?
I’m trying with a SofaBaton and am running out of patience.
Thanks!
TFerg53 - Reply Share
Past 24 Hours: 5
Past 7 Days: 25
Past 30 Days: 142
All Time: 13,575
