Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Clippers won't turn on
Clippers won’t turn on no matter what or they work intermittently.
Switch is turned on/device plugged in
Make sure the power switch is completely rotated to the on position and that the switch is not too loose. Make sure that the power cord is securely plugged into an electrical outlet (with appropriate voltage), if the clippers fail to operate.
Motor is dead
It is possible that the motor will not move because it is just jammed or needs cleaning and lubrication. The motor may also require replacement if this does not solve the problem.
Cord is frayed
Examine the cord, including the plug, for signs of wear. If it is frayed and then be sure to replace the cord. Do not store the hair clipper with the power cord wrapped around the casing as this can damage the cord.
Clippers not cutting close enough
Clippers do not cut hair close or snags hair in stead of cutting it.
Clippers have missing or defective parts
Clippers are leaving gaps of differing hair lengths when they pass over the scalp. It is possible that your guards or blades may be missing some parts. Carefully inspect your guards or blades to see if they are missing any teeth. Another cause for these cut gaps could be interference from foreign objects. Your blades may not be adjusted properly or you may have dull or rusted blades. If so, replace the missing or defective parts.
Device vibrates excessively
Clippers are vibrating more than usual and are very loud.
Missing or defective parts
Missing parts such as screws or a cracked casing can be the cause of your clippers malfunction.
Improper adjustment
The clippers may be improperly adjusted due to normal wear and tear or from being dropped enough times.
Clippers running slow
Clippers may be running slower than usual and taking several passes to cut hair.
Cord may be malfunctioning
Inspect the cords connections to see if there are internal wiring issues that could limit clipper power, such as arcing or a wire break.
On/Off switch may be malfunctioning.
Inspect the switch mechanism for signs of pitting and arching. If it's not clean and doesn't make contact then the correct amount of current will not flow to the motor.
Motor may require replacement.
The motor may be beyond repair and need to be replaced. Hopefully this is not the case because the Andis clippers usually don't have a significant manufacturer's warranty and the price of the motor is fairly hefty.
David Taylor
169 Reputation
1 Guide authored
USF Tampa, Team 1-34, Donnelly Fall 2014 Member of USF Tampa, Team 1-34, Donnelly Fall 2014
USFT-DONNELLY-F14S1G34
1 Member
12 Guides authored
30 Comments
Hello, I have an andis envy adjustable blade clipper. I have used it only a few times(maybe five). The last time I tried to use it, it buzzed very loud and the blades were not moving to cut. Not sure what to do. Help please!
acerocke - Reply Share
They are probably stuck from not being used
Carlos-mega Robles - Reply Share
Have you fixed that, I got gift of Andis Pro complete pack once I open it the big machine motor is working but blade is not moving neither it’s cutting hair can anybody suggest what I have to to.
Mazhar Khatri - Reply Share
Red wire came out the coil
Tyrone - Reply Share
How do I fix it
Past 24 Hours: 6
Past 7 Days: 18
Past 30 Days: 100
All Time: 73,411
