Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Amazon Fire HD 8 Plus 12th Gen Troubleshooting
The Amazon Kindle Fire HD 8 12th Gen is a tablet made by Amazon that was released in 2022 it is the 8th generation of tablets in the Kindle Fire HD series.
Not starting up
Brief freezes or issues when starting up device Tablet freezes upon startup
The tablet will freeze upon startup or will not turn on at all. This issue can be fixed by doing a force reset by holding down the power button for around forty seconds and pressing the power button again which will clear out any glitches that may be causing the issue.
Faulty Battery or charger
The problem may be caused by an empty battery leave it to charge until the light turns green indicating it is full before turning it on. if you suspect that the battery isn't working try to use a different charger or replacing the battery.
Tablet not charging or slow charging
The battery will simply refuse to charge or charge slowly.
Broken charger
Try using a different charger to make sure the cable and charger are not broken if it is still not working plug it in into a different outlet.
Loose charging port
If the charging light is not appearing then try to push the cable or move it gently this is due to loose charging ports.
No audio from headphone jack or speakers
There have been reported issues with the audio not working as it does not reach the speakers or headphones.
Headphone jack or speakers not working properly
This could potentially be due to the tablet case or headphone jack. If the speakers are not working try putting on headphones. If headphones don't work try to move the headphone jack a little.
Tablet Case blocking speaker
Sometimes a tablet case may obscure the speakers if you suspect this remove the case.
Volume may be down
Push on the volume up button on the side of the tablet or go to settings and then sound to control the volume.
Hardware issues
If you purchased the device and didn't cause the damage you can claim insurance and if it is under warranty you can contact amazon to get it fixed.
The tablet won't connect to wifi
Wifi symbol wont appear and web based applications don't load.
Bug causing the issues
The tablet refusing to connect to wifi may be a simple bug that can be fixed by doing a soft reset on the tablet.
Router or modem issues
It may be an issue with the router or a hardware issue in which case you should contact Amazon.
Stuck on Amazon logo screen upon startup
This may be caused by low charge on the tablet.
Low battery
''''This can be fixed by charging the tablet for at least 30 minutes and holding the power button for 10-20 seconds, additionally,
Plugging into other devices
Some users have gotten past this issue by plugging the tablet into a computer
Recovery mode
You might have to reboot the system by going into Recovery Mode. To do so, first power off the device. Turn it on and press and hold the power and volume down buttons simultaneously. Navigate to the Reboot System Now option using the volume up and down keys. Press the power button to select this option.
Hardware issue
The problem may be caused by a hardware issue in which case contact amazon support so they can fix it.
Author
with
Alan Alejandro Ramos Avalos
547 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 46
All Time: 561
