Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Device is not connecting to Wi-Fi
The device does not connect to Wi-Fi and cannot access its features.
Device not connected to Wi-Fi network
Go to your settings on your Echo Look on the Amazon Alexa App and make sure that Wi-Fi is enabled. If it isn't then enable it and connect it to your home network.
Wi-Fi Interference
Try moving the Echo Look closer to your Wi-Fi router. Moving the Echo Look away from walls and interference sources like microwaves and baby monitors may help.
Incorrect Password
If you have password-protected Wi-Fi, have changed passwords, or changed routers check the Amazon Alexa App to see if you need to change/input your individual Wi-Fi password.
Malfunctioning Wi-Fi Module
The Wi-Fi module on your Echo Look’s motherboard may be broken or damaged. A replacement motherboard will be needed.
Not responding to Voice commands:
The device does not respond to voice commands.
Microphone Blockage
Check if there's anything blocking the device's microphone. Ensure that the microphone area is clean and free from obstructions.
Low Volume
Make sure the device's volume is set at an audible level.
Background Noise
High background noise levels can interfere with the device's ability to hear your commands.
Distance from the Device
Ensure you're within a reasonable distance from the Echo Look when giving voice commands.
No/Bad Wi-Fi Connection
If your device is not connected to the internet or is experiencing Wi-Fi issues, it may not respond to voice commands.
Muted Microphone
Check if the microphone is muted. On some Echo devices, there's a physical button or switch to mute the microphone.
Device Software Not Up to Date
Ensure that your Amazon Echo Look is running the latest firmware. Updates may include improvements to voice recognition.
Alexa App Issues
Sometimes, issues with the Alexa app can affect voice recognition. Ensure that the Alexa app is up to date and working correctly.
Device not charging
The device will not charge.
The power cord is not plugged correctly
Like other Alexa models the Echo Look will have a round port on the back for the charger to insert. The insert should be pushed in until it cannot go further.
The power adapter should also be checked if it is completely inserted to a working outlet.
Damaged Cord
The power cord may have a short or a broken wire. Check the cord for any frayed or damaged areas. If any damage is found, replace the power cord.
Malfunctioning motherboard
This will only be the cause if all speaker functions cease to work, the motherboard has to be replaced.
Faulty Battery
The battery in the Echo Look might be faulty, which will cause the Echo Look to boot up very slowly. In this case, a replacement is necessary.
Device taking too long to start up
The device takes more than a few seconds to boot up and is stuck in the booting animation.
Faulty battery
The battery in the Echo Look might be faulty, which will cause the Echo Look to boot up very slowly. In this case a replacement is necessary.
Faulty power adapter
The power adapter may be malfunctioning in some way which may cause a boot loop. Replugging or replacing the power adapter should work.
Camera Pictures are Low Quality
Pictures on the Amazon Echo Look appear low quality and fuzzy. Pictures are hard for the device to recognize.
Cracked or Foggy Camera Lens
The lens for the camera might be cracked so the device can't take good pictures of its features, and the cracked lens needs to be replaced.
Check to ensure that the camera lens is not obstructed by any debris or by your hand.
Author
with
Ryánn Gillen
428 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 39
All Time: 513
