Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Aluratek Digital Frame buttons don’t work
Nothing happens when I press the buttons in the back of the frame.
Sticky Buttons
Something probably spilled on the buttons causing them to not work and be sticky. You are going to want to replace the buttons.
Will not display pictures.
Your Aluratek ADMPF310F will not display any images.
Motherboard Defective
If you digital frame doesn't display any images you may have to replace your motherboard inside the frame.
The Screen Is Damaged
I want to display my pictures clearly but I cannot.
Cracked Screen
Open the Aluratek using the tabs around the outside, disconnect all necessary wires and place and plug in new screen
Black Screen
The charger may not be fully plugged in or working, make sure the cord is fully plugged in. If that does not work find replacement plug
Dead Pixel
Keeping the picture frame always plugged in may cause the screen to burn out pixels. Replace screen by opening device and unplugging and replacing old one.
Remote Doesn't Work
None of the functions on my Aluratek remote are working on my Aluratek picture frame
Dead Batteries
The batteries in the remote may be dead, replace with two new AA batteries
Sticky Buttons
The remote may be old and have dirt lodged in them causing the remote to not send a signal. Use canned air to clean out buttons
Bad Receiver
The receiver in the Aluratek frame may be damaged or not working, replace by taking off the screen and unclip and sauder new receiver in.
Speakers don’t give any sound
My music won't play on the frame
Cable Might be broken
It is possible for the cables that are inside the device to dislocate and that can cause speakers to give no sound. Make sure your cables are connected by opening the device.
Dirt and dust build up
There could be minor dirt and dust build up in your device that causes your speakers to make no sound. Make sure to clean your speakers.
Displacement of the speakers
Dropping the device or a hard hit could cause speakers to dislocate from their hole. It is important to use the device gently.
Settings error on device
The reason for it could be a settings error. Make sure to go on setting on the device and check the speakers options to see if they are enabled or not.
Author
with
Kelsea Weber
21,643 Reputation
32 Guides authored
iFixit, Team S1-G1, Weber Summer 2018 Member of iFixit, Team S1-G1, Weber Summer 2018
FIX-WEBER-SU18S1G1
5 Members
396 Guides authored
24 Comments
My problem: The pictures show upside down. I can rotate them in the browse mode, but as soon as I go to the slide show mode they reapper upside down. On my computer, the picture files appear the right way without any rotation necessary... how to permanently set the picture frame with the pictures in the right orientation ?
LINDA LOVE - Reply Share
the device is plugged in but it wont turn on, either with the power button or with the remote. Help!!
Katerin Ariola - Reply Share
It keeps telling me that the USB is removed. But it isn't.
a.malony - Reply Share
I cannot get my WiFi on the frame to “enable”. The frame message says the frame WiFi is disabled but it is not, it is turned on. Any suggestions would be appreciated.
she.said - Reply Share
When connecting to the Wi-Fi it says Wi-Fi disabled but it is not
Colleen Palmer - Reply Share
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 45
All Time: 12,932
