Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Battery Runs Hot
During use, the battery feels hot to the touch.
Fan Vent Blockage
Check fan vents and ensure there are no blockages. If vents are blocked, it will restrict airflow needed to keep your laptop from running hot.
Dirty Fan
If the vents are clear of blockages, the problem could be with the fan itself. Remove the fan door and clean the fan with compressed air.
Faulty Battery
If the vents are clear, the fan is clean, and the battery still runs hot, consider replacing the battery using this guide.
Battery Life Does Not Last
The laptop constantly needs to be charged.
Faulty Power Adapter
Ensure the power adapter is plugged in and the charge light is on. If the light is not on, and the adapter is plugged in, the adapter is faulty. Consider purchasing a replacement adapter.
Faulty Battery
Ensure the power adapter is plugged in, the light on the adapter is on, and ensure the adapter is connected to the laptop to charge the battery to maximum capacity. If the laptop battery life still seems to be short and functions best when the adapter is plugged into the laptop regardless of charge time, then the battery is faulty. Replace the battery using this guide.
Unexpected Computer Crashes
During use, computer will randomly restart.
Fan Vent Blockage
An overheating battery may cause crashes. Check fan and vent to be sure they are clean and clear. If dirty, clean the fan with compressed air. If cleaning does not work, then opening up the laptop more fully to inspect the fan may be necessary. If all else fails, the fan may need to be replaced.
Defective Hard Drive
If your laptop keeps reading files as corrupted, will not properly download programs and eventually will not turn on at all then your hard drive is corrupted and you will need to replace it in order for the laptop to run properly. The laptop will not run until a properly working hard drive is installed. To replace the hard drive, please refer to the hard drive replacement guide.
Malware
Malware may cause system crashes. Run an anti-malware program to ensure no malware is present.
Blue Screen Of Death
A blue screen appears either during use or when initially powering up laptop.
Fan Vent Blockage
Overheating may cause the blue screen of death to appear. Check fan and vent to be sure they are clean and clear. If dirty, remove the fan door and clean the fan with compressed air.
Corrupt Program
If your laptop fails to load normally but can run in Safe Mode, then a program you installed is corrupted and is keeping your laptop from operating normally. Run your laptop in safe mode by pressing F8 when turning on your laptop before windows can load. Another way to run in safe mode is by executing a force shut down on your laptop. The system will ask if windows should be ran normally or in Safe Mode the next time the laptop is turned on--select Safe Mode. If your laptop runs in safe mode, then a program you installed is causing the blue screen to appear and will have to be uninstalled . Access the control panel by clicking the start menu and searching for "control panel" in the search bar. Here programs can be uninstalled by clicking "Uninstall A Program" under the "Programs" section.
Computer Programs Crash
Sometimes programs will close on their own during use.
Faulty Graphics Driver
Frequent program crashes may be due to faulty or outdated graphics drivers. To install new graphics drivers, search google for Nvidia. Click the link that says "Drivers-Download Nvidia drivers. You will be taken to a web site were you can download new drivers.
Faulty Hard Drive
Frequent program crashes may be linked to a faulty hard drive. Replace the hard drive using this guide.
Faulty Motherboard
Program crashes can also be caused by a faulty motherboard. Replace the motherboard using this guide.
Author
with
Jonathon Tschurwald
887 Reputation
4 Guides authored
UW Tacoma, Team 1-1, Rose Winter 2017 Member of UW Tacoma, Team 1-1, Rose Winter 2017
UWT-ROSE-W17S1G1
3 Members
48 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 38
All Time: 2,720
