Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Phone Responds Slowly and/or Freezes
Phone takes too long to load information and swiping motion is not as smooth.
Phone needs to be rebooted
  • Try resetting the phone and rebooting the phone. You can do this by simply turning off the phone for about 5 min. And then turning it back on.
Too many apps running
  • Try deleting some downloaded apps if not all. This can help open up more storage and retrieve some applications that might have been slowing down the phone
Reset to factory settings
  • Finally, if all of the above failed, try resetting the device to its factory settings by holding the home and volume button.
Phone will not turn on
You have trouble turning on the device.
Low power
  • If the phone shows no response, try connecting the phone to a power source for 5 minute, then try turning on again. If the problem continues, remove the back cover and take the battery out then put it back in, doing that will reset the phone.
Damaged/Dead Battery
  • If for some reason the phone will still not turn on after charging it for at least 20-30 min. that may mean that the battery is in need of a replacement. You can easily change it by taking out the old one and replacing it with a new one which can be obtained from your phone company.
Phone has Problems Receiving Calls
You are not able to receive any call.
Airplane Mode
  • Airplane mode will turn off any wireless connection from the phone and will prevent it from receiving calls. If you are not receiving calls go into the wireless network settings and make sure that airplane mode is off.
Faulty SIM card
  • You can remove the back cover to the phone to reveal the SIM card slot. Simply pull the card out and talk to your service provider to get a new one to put back into the phone.
Phone Turns off Unexpectedly
Phone suddenly turn off on you.
Damaged/dead battery
  • Phone most likely has a very old battery that can not keep up with its daily use. Try replacing it with a new battery by taking out the old one and putting in a new one which you can get from your phone distributor.
Overheating
  • If the phone seems hotter than usual, let it rest for 15 minutes before attempting to turn back on. This could indicate that the phone has been working its processors hard and caused it to shut down to protect the system from any damage.
Unable to Install or Update Apps
You are unable to install or update any app.
Log in
  • If you phone is having trouble updating your apps, this could simply mean that your phone is not logged in to the play store. Simply go to the play store and log in to the account. This should allow the phone to start the most recent updates to your apps.
Memory full
  • If the phone memory is full, the phone will not allow you to install more apps. To solve this, go through your downloaded apps, gallery, and messages to delete what you don’t use. This should clear up memory for the phone run updates again.
Author
with
Richard
36,405 Reputation
11 Guides authored
2 Comments
This phone is another TCL turd. I've never seen a worse phone! Also limited to Sprint network only!
Matthew Allen - Reply Share
what if its stay at the screen you turn it on for the first time
Alex Vazquez - Reply Share
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 21
All Time: 608
