Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Black screen
Your screen is not turning on when you're pressing the power button.
No power
If your monitor is not receiving power, the power cables of the monitor may have become loose and power isn't reaching your monitor. Make sure that the monitor is securely connected to a working power source and that the cables are not frayed or pulled free from their connections.
Low brightness setting
Sometimes the display of the screen is set on low to conserve power or has been accidentally manually set. Power conservation mode can be a reoccurring problem if your computer is set to go into energy saving mode. Try to access the display settings by your keyboard command buttons. There is usually a power/battery icon button in the lower right corner of your screen. If you click the icon it will direct you to your power manager from which you can change your power settings.
Corrupt new software
If you have recently had a software update and your screen went dark shortly after this update, then you might have corrupt software. Sometimes corrupt software can be easily fixed by rebooting your system; restarting might trigger a better compatibility between the monitor and the software. If rebooting does not fix the problem, use the system restore function found by searching 'system restore' in the windows home search, to restore your computer system to a point before the update. Alternately, try re-installing the software that is causing the problems.
Lines on screen
Your screen has horizontal or vertical lines on the display when turned on.
Bad cables
If lines appear on your screen, you may have loose or faulty cables. Check the DVI or VGA cables connecting your monitor to your computer. Ensure the cables are securely connected to the correct input. If the problem persists, try using a new set of DVI or VGA cables.
Old drivers
If you are experiencing screen glitches a common source of this problem is outdated drivers. Check that you have the most current hardware drivers for your monitor and video card.
Bad power supply
If lines appear on the screen, many times a bad power supply is the cause of this problem. Check to see if the power cables are securely connected to the monitor. To check for updated drivers, go to the device manager in windows and find the malfunctioning device in the list. Right-click on the device name and go to the properties window, which will display if the drivers are up to date or not. Also, make sure the power cables are connected to a working power outlet.
Bad internal cables
If there is a distorted picture, a common cause is a loose cable inside the monitor. This requires disassembly of the monitor in order to repair the problem. Check that the various internal cables are securely fastened. To see the steps to check the cables, click here.
Bad screen
If lines appear on the screen there is a possibility that the display screen is damaged or faulty. In this scenario, the display screen may need to be replaced with a new screen.
Sticky buttons
The buttons on the monitor are sticky or not responsive.
Residue under buttons
There might be unwanted residue underneath the buttons. A common solution for eliminating residue is by taking a can of compressed air and spraying around the button. If the problem persists you might have to open up the monitor and repair it.
Monitor turning on and off
The picture on the monitor is turning on and off for short periods.
The screen is switching between a standby and an active mode
When set to maximum resolution and brightness, the screen may switch off to protect itself or to save power. This problem can be solved by restoring the screen to more efficient resolution and brightness settings. To change the brightness, use the brightness button on the lower right-hand side of the monitor. The brightness button will open up a menu allowing you to manage your brightness settings. Alternatively, the menu button, located next to the brightness button, will make a pop-up menu appear on the screen. If given the choice, click on the “Auto” or “Auto-Adjust” option.
The capacitors are faulty
If the monitor has issues turning on and off the capacitors, which give power to the monitor, may not be working properly. This results in the screen flickering on and off.
The ribbon cables are not firmly attached
If the ribbon cables are not securely connected, the picture on the screen will sporadically turn on and off. For a repair guide on replacing or reconnecting ribbon cables, click here.
Distorted colors
The picture on the screen has distorted colors.
Bad cables
A common source for distorted colors is loose or faulty cables. Check the DVI or VGA cables connecting your monitor to your computer. Ensure the cables are securely connected to the correct input. If the problem persists, try using a new set of DVI or VGA cables.
Old drivers
Outdated drivers could be the cause to this problem. Check that you have the most current hardware drivers for your monitor and video card.
Bad power supply
Many times a bad power supply is a reason why color distortion occurs. Check to see if the power cables are securely connected to the monitor. Also, make sure the power cables are connecting to a working power outlet.
Bad internal cables
A loose cable inside the monitor may be causing the picture distortion. This requires disassembly of the monitor to repair the problem. Check that the various internal cables are securely fastened. To check the cables, click here.
Bad Screen
If color distortion occurs, there is a possibility that the display screen is damaged or faulty. In this scenario, the display screen may need to be replaced.
Author
with
Jeffrey Kong
927 Reputation
5 Guides authored
Cal Poly, Team 12-3, Forte Fall 2014 Member of Cal Poly, Team 12-3, Forte Fall 2014
CPSU-FORTE-F14S12G3
5 Members
60 Guides authored
5 Comments
lines on screen
krithika sreekanth - Reply Share
just replaced my old monitor with ACER LCD monitor Model SA220Q/SA230 now i do not have any audio, i had been using external speakers.; any suggestions
Fred Reubi - Reply Share
i just installed an acer monitor. when i start up the computer (the monitor is “on”) the screen flashes “acer” then flashes my “desk top”, then goes black (but still stays “on”.)
what could be the problem? this is exactly what happened with the old monitor so i thought the monitor needed to be replaced. i am assuming that the problem was the same as this acer monitor.
what can i do to get the monitor to “not go to black” ?
blseames - Reply Share
My monitor was working fine until I had to get a new computer with Windows 10 (upgrade from 8.1) I have no red or green & a “baby $@$*” yellow. Help!!
Peggie Fanning - Reply Share
how do I get rid of this yellow number on screen far right hand corner? The number is 144 I think it has something to do with the mode ( ie: G3) but when I try to change it with the buttons in back I am not getting a way to change. In other words I cannot select. Please help
This is a monitor only
patricia tarkington - Reply Share
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 57
All Time: 17,877
