Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Device is Unresponsive
The laptop doesn’t show any signs of powering on and is unresponsive.
Defective Power Adapter
Is the power adapter fully plugged in, and if so, is the light that indicates it is plugged in on? If not, that means the adapter is faulty, and you should consider buying a replacement adapter.
Defective Battery
The laptop boots up while plugged in but does not turn on or stay on when disconnected from power. You can replace the battery with this guide.
Broken Motherboard
If you attempt to charge your laptop, it will start to boot up but shut down immediately after. Also, if you have screen issues, like a blue screen that won’t go away or the display freezing, you may have a problem with your motherboard. Replace the motherboard using this guide.
Display Not Working
The laptop’s display might be very dim or completely black, but the rest of the computer is running.
Display is Disabled
The display might be disabled. To fix this, hold the “Fn” key located near the bottom left of the keyboard and press “F5.” If the display is disabled, this will re-enable the display.
If this does not fix the issue, repeat the above step once more. Then, hold down the Windows key and press “P” twice. The computer may have been set to “Second screen only,” which will set the computer back to “PC screen only.”
Display is Broken
The display of the device may be broken and require replacement. Replace the display using this guide.
Laptop is Overheating
The device is warm or hot to the touch and may be shutting down during usage.
Vents Are Blocked
Any excess dust can get trapped within the device's vents and/or fans and cause the device to overheat. Carefully cleaning off the dust will resolve this issue.
Faulty Fan Assembly
If you notice your laptop is silent and there is no airflow by the laptop vents, try replacing the fan assembly using this guide.
Old Thermal Paste
You may need to replace the thermal paste. If your cooling fans need to be replaced as well, you can restore the old thermal paste in conjunction with replacing the cooling fan while the laptop is disassembled. You can find a thermal paste like Arctic Silver Thermal Paste and the guide for replacing it here.
Keyboard /Keys Not Responding
The keys have no response, and/or they appear damaged.
Key Stuck
When a key is pressed, is there a delay to the key popping back, or is the key remaining pressed down? Remove the key and check to see if something is interfering with the key. Then wipe the area clean underneath, then place the key back.
Missing Keys
If a key is missing, replace it by popping the new key into place.
Touchpad Not Responding
The touchpad on your device is not responding.
Touchpad Disabled
The touchpad might be disabled. To fix this, hold the “Fn” key located near the bottom left of the keyboard and press “F7.” If the touchpad was disabled, this will re-enable it.
Touchpad is Broken
The touchpad of the device may be broken and require replacement. Replace the touchpad using this guide.
Melanie Veilleux
112 Reputation
0 Guides authored
UMass Dartmouth, Team 5-1, Sinclaire Fall 2022 Member of UMass Dartmouth, Team 5-1, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S5G1
5 Members
84 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 30
All Time: 1,211
