Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Screen Does Not Display Correctly
The monitor on your Acer Chromebook CP5-471-C0EX does not display anything.
Screen Turns On But Doesn’t Display Anything
Power the device off and back on. If the screen still does not display, then press the “power button” and the “restart button” (the fourth button from the top left of the keyboard) at the same time until the device powers down and restarts. Repeat this step until the device displays a blue screen upon restarting.
Blue Screen
This can usually be fixed with a simple restart of the computer which is done by holding down “esc + reload + power button.” Doing so this way has the least likelihood of causing damage to your system. You can also perform a manual restart by powering the device off and back on again; however, there are possible adverse side effects to this method, including damage to the system.
Screen Won’t Turn On
First, check that the device is powered on by pressing the “power button” at the top right corner of the keyboard. If the screen still does not display or the device does not power on, it may be out of charge. Plug the device in to charge and attempt to power it on again.
Audio Is Distorted
You have trouble listening to sounds on your computer.
Volume is either too loud or too quiet.
Volume Won’t Adjust
Click on the taskbar in the bottom right corner of the screen. From there, try adjusting the volume using the slider. If you are using speakers or headphones, make sure the device is selected as the correct output device.
Faulty Headphones
Make sure your headphones are securely plugged in. If you are unable to plug in your headphones, try another working pair of headphones. If issues persist, you may want to try turning off the laptop, plugging in your headphones, and then powering the laptop back on. This will allow the laptop to scan for audio devices. If after this step, you are still unable to connect your headphones, you may be dealing with a loose headphone jack.
Distorted Audio
Check to make sure sound drivers are up to date. Ensure that sound is enabled both through sound settings and via the sound function keys. Lastly, inspect the speaker holes for any debris that may be blocking the sound.
Computer Will Not Power On
The laptop will not power up or show any signs of powering up.
Charger is Faulty
Ensure that device is fully charged and that the charger is fully functional. Try performing a hard reset on the laptop. To do this, hold the “power button” down for 30 seconds.
Loose Charge Port
Check if your charger is completely plugged in, both into the Chromebook and the wall. Unplug your laptop from the charger and the adapter from the wall. Plug in the AC adapter into the wall and laptop port, feeling the physical port to see if it may be loose. If the port feels loose, it may need to be replaced.
Trackpad Movement Stuck
The trackpad on your laptop gets stuck, You are not able to easily glide fingers across.
Mouse Sensitivity Set Too Low
Go to system settings and open the device settings tab, then open the trackpad settings. Changing the mousepad sensitivity may help with difficulty when trying to move the mouse
Trackpad Driver is Out of Date
If problems still occur, the issue may be the drivers. To access the drivers, search for “Driver Manager” in the Start menu, and click the dropdown for “Mice and other pointing devices”, click on the touchpad to open its setting, and open the Driver tab, then click “Update Driver”. If after the drivers are updated you still experience issues, you may have to replace the trackpad.
Device is Overheating
While you are working, your computer randomly shuts off without notification.
Dust in Vents or Fan
Computers can overheat due to excessive dust and other materials stuck in the vents or fan. To fix this, use a compressed air duster to carefully blow the dust off the vents and fan. It may also be necessary to finish cleaning the blades of the fan with a cotton swab and alcohol solution. Be careful not to damage the delicate fan blade while applying the solution.
Not Enough Thermal Paste
Your laptop may not have a good amount of contact between the heat sink and the processor. This is usually caused by a lack of thermal paste. To fix this, completely clean any old thermal paste off, then apply a bead of new thermal paste directly in the center of the processor. Gently push the heat sink back in place and tighten screws to lock down the heat sink.
Aida mohamed
186 Reputation
1 Guide authored
Gateway, Team 1-1, Saknee Spring 2022 Member of Gateway, Team 1-1, Saknee Spring 2022
GCC-SAKNEE-S22S1G1
4 Members
60 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 20
All Time: 859
