Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Device Won't Turn On
The laptop is unresponsive and won't power on
Device not plugged in
Plug your Chromebook's charging cable into a working power outlet. If the charging light turns on but the laptop will not start, try to recover the laptop to an earlier date when it still worked. If the laptop won't start at all, make sure the connections are secure and let it charge for 15-30 minutes. If the laptop is not charging or the steps below don't work you may need to contact the manufacturer.
Faulty Battery
If the laptop has been out of use for an extended period of time, it could be unresponsive due to a faulty or uncharged battery. Test the battery by unplugging any extra peripheral devices and plug the laptop charger into an outlet. The charging light should turn on; if not, check to make sure the connections are secure. If the battery is not charging it may need to be replaced. Find our battery replacement guide here.
Faulty Motherboard
If the power supply is working and the fans are working, but your device won't power on, you may need to replace the motherboard. Find our motherboard replacement here.
Black Screen/Display Errors
The device might be asleep, so hold down the power button to turn on the device. If the laptop has power and it's still not displaying, the screen might be dimmed. Ensure that the brightness is turned up by repeatedly pressing the F7 key. If your screen appears patchy, there is a chance that your Chromebook has dead pixels. This is a good indicator that your device has a faulty LED screen. If the issue still persists, your screen may need to be replaced.
The Keyboard Is Not Functioning Physically
Key(s) on the keyboard are not functioning properly, are stuck, or are missing.
Keys are Stuck
If the keys cannot be pressed down there may be debris under the keys preventing them from working properly. Carefully remove the key and clean the debris that is preventing the key from functioning correctly. Make sure the keyboard area is completely clean and then carefully attach the key(s) back to its original position.
Keys are missing
If the keys are detached from the keyboard and cannot be found, then replace the keys. Be sure the area is clean before proceeding with the replacement process. Find our key replacement guide here.
Laptop isn't playing audio
Audio and sounds are not playing from the laptop.
Muted Volume
Make sure the sound isn't muted by clicking your account photo and adjusting the volume using the slider. If it isn't muted, next to the volume slider, click the Right Arrow and change where the sound is coming from (output). If this doesn't work, unplug any audio devices from your Chromebook and test the sound. If problems still persist you may need to Reset your Chromebook or Recover your Chromebook.
Faulty Speakers
You may need to replace your speakers if the sound will still not work after resetting your Chromebook.Find our speaker replacement guide here.
Track Pad Unresponsive to Touch
The cursor will not move when the user touches the track pad..
Corrupted Software
If your track pad is unresponsive to touch, your Chrome OS software may be corrupted. Try uninstalling and reinstalling Chrome OS.
Faulty Track Pad
If the track pad is still unresponsive to touch after the software has been reinstalled, you may have a faulty track pad. Find our replacement guide here.
adamhendrix
279 Reputation
0 Guides authored
USF Tampa, Team S11-G1, Passmore Fall 2017 Member of USF Tampa, Team S11-G1, Passmore Fall 2017
USFT-PASSMORE-F17S11G1
3 Members
60 Guides authored
5 Comments
My Acer Chromebook CB3 131 just suddenly turned off and became unresponsive. The screen has no display and the fans are not in use. I have tried to turn it back on by holding down the power button, but it is still unresponsive. The power light is on, but it will still not display. Can anyone help?
Gnomathy Gnomathy - Reply Share
My Acer Chromebook CB3-131 is unresponsive. When I closed it the bottom left corner of the screen disconeted and after then it didn’t turn on anymore, the lichts for charging and sleepmode are both of even when connected to charger. I think that something connected to the screen broke ,but I do not know what or how to fixs it. Can someone help?
Thiska Nijkes - Reply Share
can you replace the ssd hd on this model?
R M. - Reply Share
Acer Chromebook 11 CB3-131-C3KD
is hard drive replaceable on the C3KD model?
R M. - Reply Share
My chromebook will not charge and i have to keep it on the charging cord 24/7. Is there any way to fix this???
Mason Rossi - Reply Share
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 23
All Time: 4,301
