Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
The Computer is Showing a Black Screen
Your computer screen is unresponsive and appears dark even though it is powered on.
Damaged Display
If your Acer Aspire 3003 WLCi is only showing a black screen, first check its display for any signs of physical damage. If you see cracks, breaks, or bumps on this part of the laptop, you will need to replace the display.
Malware is Present on the Device
If your black screen is not due to physical damage to your laptop’s display, it may be caused by malware. To remove the malware, you must reset the laptop so that you can download an anti-malware program.
Operating System Experiences Critical Error
In the event that the black screen is caused by an OS crash, first restart your computer. If this restart fails, you may need to perform an OS reset. In some cases, an OS error can be caused by faulty hardware hardware that must then be repaired or replaced.
Overheating of Internal Components
Sometimes a black screen error can be caused by overheating hardware. If this is the case, you will need to determine which component(s) are having trouble cooling down. Then, you should either replace the component if it is damaged beyond repair, or keep the part, ensuring that all exhaust ports and fans are clear for optimal cooling.
There is No Battery Detection
Your computer does not show the battery percentage icon in the bottom corner of the screen.
Battery Is Damaged
If your Acer Aspire 3003WLCi does not detect its battery, first check to see if the battery is damaged or dead. If this is the case, the battery must be replaced.
Charging Port is Damaged
Sometimes, laptops may have trouble detecting a battery if there is something wrong with their charging port. Inspect the charging port of your laptop to see if you find any dirt, dust, or broken pieces. If you find that the charging port is dirty but intact. If you find that the charging port is broken, you will have to replace this port.
BIOS Must Be Updated
Your laptop may struggle to identify its battery if its BIOS (basic input/output system) is out of date. The BIOS helps your computer to detect any inputs (like power from a battery) or outputs of the device. Try updating the BIOS on your computer to solve this detection failure.
The Computer is Overheating
Your laptop is reaching critically high temperatures, likely causing loud noises from internal fans and potentially resulting in resetting at strange times.
Improper Laptop Care
Before opening up your computer, make sure that you take a look at how you use it. If you keep your laptop on your lap or wedged between items on a cluttered desk, this may cause the laptop to overheat. This is because using a laptop in this way is likely to block its exhaust ports, preventing heat from escaping. If you do either of these while using your laptop, try placing it on an uncluttered desk instead to see if this helps reduce overheating.
Dusty Fan/Exhaust Port
If the overheat does not stem from your general usage, open your laptop and find any fans or exhaust ports. Gently clean any dust or dirt off of these components. A buildup of such materials also prevents heat from escaping the laptop.
Degenerated CPU/GPU Thermal Paste
If the internal fans and usage are not the cause of the overheat, there may be degeneration of the thermal paste used on the CPU or GPU. This paste is meant to draw heat away from these components and prevent any heat damage. However, the paste degenerates over time, and will need to be replaced.
The Computer Performs Poorly
Your laptop is running slowly and its performance has declined.
Too Many Tasks/Programs
If your laptop isn’t running as efficiently as you’d like (or are used to), it may be due to the number of background tasks occurring at a given time. To eliminate some unnecessary background tasks that may slow your computer, you can utilize the Task Manager tool.
Hard Drive is Full
In addition to an abundance of background tasks, a full hard drive can certainly cause a computer to slow. Make sure you go through any documents, programs, or pictures you have saved to your hard drive and delete what you don’t need to conserve space. If you need everything on your hard drive and simply want more space, you can replace your current hard drive with a higher-capacity one.
Malware/Virus Scan
Malware can also be the cause of poor laptop performance. To remove the malware, you must download an anti-malware program.
The Computer Keeps Freezing/Resetting at Seemingly Random Times
Your screen is jittery, frozen, or powered off without you pressing the power button.
Faulty RAM
If your Acer Aspire 3003WLCi’s screen is freezing or resetting itself, the culprit may be faulty or broken RAM. This means that you will need to replace the stick of RAM within your laptop.
The Computer is Experiencing Repeated Program Crashes and Software Errors
Your computer will not start up and/or execute programs properly.
Faulty Hard Drive
If your laptop cannot detect your hard drive, there may be a hardware failure that is preventing the component from being detected. In this event, your hard drive will be in need of replacement.
Laptop is Not Powering On
Your laptop will not respond when pressing the power button
Dead Battery
If your Acer Aspire 3003WLCi fails to power on, it is possible that the battery has died. In this event, you can either choose to replace the battery (recommended) or simply use the laptop without a functioning battery, in which case it must always be plugged into an outlet. This is not optimal, as the purpose of a laptop is to provide mobility.
Capacitors Insufficiently Discharged
There is a particular phenomenon that can occur in which your laptop’s internal capacitors haven’t discharged sufficiently, preventing it from booting properly. To fix this, you’ll need to drain these internal capacitors of their residual electricity. This can be done by holding the power button for up to 60 seconds.
Tristin Viale
675 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 36
All Time: 710
