Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Laptop Will Not Charge
The laptop does not show any signs of charging.
Missed Connection
Check the plug-in to both the outlet and to the laptop. It is important to ensure that both plug-ins are properly connected; otherwise, the laptop will not be able to charge.
Faulty Outlet
It may sound silly, but more often than not, the outlet is the cause of the problem. Unplug the charger from both the outlet and the laptop, and try a new outlet.
Frayed/Broken Charger
Feel the charger’s cable, and check if there are any bumps, cuts, or tears in the cable. If so, that could be the cause of the disconnect. You will need to look into replacing your charger, so that you are able to safely charge your laptop.
Faulty Battery
If the charger is not the issue, it is time to look at the battery. Remove the battery, wait a few moments, and then place it back in the laptop. If there is no power, the battery may be the issue. Without a strong battery, a laptop will not be able to hold a large enough charge to power on the laptop. Batteries decay and become less effective as time passes. Look into replacing the battery and see if that resolves the issue.
Laptop Does Not Boot
The laptop appears to be powered-off and will not turn on.
Faulty Power Outlet
Check that your laptop is plugged in and charged. In addition, the issue may be with the outlet you are using. Try a different outlet and see if your laptop will boot.
Power Supply Failure
If you have another power supply unit, see if using it allows your laptop to boot.
Faulty Screen
The issue may be the screen. Try turning on the laptop in a dim room to see if there is a faint image. If you hear the fan and other booting up processes but see nothing on the screen then the screen may be the issue.
Laptop Speed Is Slow
Sites or programs take a long time to load or respond.
Full Hard Drive
If your computer's hard drive is full, or nearing capacity, it can cause your computer to perform more slowly and take more time to respond as it searches for the desired program or file. Upgrading your hard drive, or regularly deleting unneeded programs or files, can help keep your computer functioning at a healthy speed.
Not enough RAM
How much RAM (Random Access Memory) determines how many programs your computer can have running at once. If too many programs are open, it can cause your computer to lag as it struggle to maintain everything. Try closing unneeded programs and limit multitasking to prevent lag.
Too many Startup programs
As your computer boots up, it begins running several programs automatically, some of which are pre-existing. Too many startup programs can drastically limit computer start-up speed and performance.
Laptop Overheats Frequently
Laptop is warm to the touch.
Obstructed Ventilation
More common with older laptops, overheating may result in laptops shutting down or showing no sign of charging. Allow the laptop time to cool down and if the issue continues, be sure that air vents are not obstructed in any way.
Damaged Internal Fan(s)
If overheating continues after giving the laptop time to cool down and checking for any obstructions of the air vents, there is good chance that your internal fan(s) are either malfunctioning and/or damaged. Upon discovering this, consider replacing your internal fan by following this guide.
Laptop’s Trackpad Is Unresponsive
Cursor shows no sign of movement.
Trackpad Is Disabled
The most common issue that users encounter when their trackpad appears unresponsive, is that the trackpad is simply disabled. To enable your trackpad, apply the following key combination: Fn + F9.
External Devices May Be Connected
If the previous key combination does not actively enable your trackpad, external devices may be connected that will interfere with the connection between your mousepad and the computer. Be sure to remove all additional devices from computer.
Operating System Is Not Responding
If the issue continues, you may find that your operating system is faulty. The operating system manages computer hardware and software resources which provide the computer it’s common services. If the trackpad appears unresponsive, consider replacing your hard drive by following this guide.
Author
with
Lesley Pfening
360 Reputation
2 Guides authored
Ohio State, Team 1-4, Wilder Spring 2017 Member of Ohio State, Team 1-4, Wilder Spring 2017
OSU-WILDER-S17S1G4
4 Members
60 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 1,288
