Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
ASUS U52F-BBG6 Troubleshooting
Computer Won’t Boot
Your computer won’t turn on or is having problems booting up correctly.
Battery Issues
If your computer turns off when you unplug it or soon after, and will not turn back on, then your battery is probably dead and you need to replace your battery. To access the battery flip the laptop over to the back and access the battery pack near the hinge by pushing down small latches to release the battery.
Power Adapter Problems
Make sure the LED light on the adapter is on when plugged. Check if the plugs aren’t bent and that all cords are plugged in on both ends. Verify that the plug is connected to the ac adapter (box on the cord). To ensure the adapter is dead, use a replaceable adapter to test it.
Unresponsive Power Button
If all else fails, reboot the laptop by pressing the power button for 10 seconds. If the power button breaks, visit our guide on how to replace an unresponsive key.
Keys Are Unresponsive
Your keys are not letting you type.
Dirt/Dust Under Keys
Gently shake the laptop at a 75-degree angle or use a compressed air duster can to get the crumbs out of your keyboard. If that doesn’t work, swab the broken keys with rubbing alcohol or a little warm soapy water to prevent the keys from stickiness.
Weak Internet Connection
Your laptop will not connect to the internet and you don’t know why!
Internal Internet Connection
Look at the internet connection on the computer to make sure it is turned on. If the internet connection is turned off, turn it on to the correct network. Check the router if the internet connection is on and you are still not connected to the internet.
Router Problems
Go to the router to check that it is on by going to either the bottom right corner to see how strong the connection is (ex: weak, moderate, strong). If the router is on but not connected to the device restart the router. Call your internet provider and explain the situation for further information.
Screen Glitches
Your computer screen went black or blue and won’t respond.
Unresponsive Screen
If your screen isn't responding as quickly as usual, try turning off your laptop. Since you can't shut down automatically, you will have to do it manually by pressing and holding down your power button, located in the upper right hand corner. Then, wait for about 30 seconds before turn it back on by pressing and holding down the power button again.
Updating Your System
Many applications have known to cause screen flickers when they need to be updated, Make sure your applications and display are updated. Some applications will automatically ask you to update their program (ex: Adobe Flash-drive), but for some you must do it manually. You can go to our Additional Information page to seek further assistance.
Cracked Screen
Examine to see if there are any cracks on your screen, if so you may need to replace it. We do not recommend replacing the screen without the proper tools and guide. If you need assistance with replacing a new screen, try our Screen Replacement Guide.
Camera Issues
"Your camera isn't working and you don't know why!"
Cracked Lens
If your camera isn't working or you can't see the image, it could be because your camera lens is cracked. To do this you will need to take apart your screen, but don't worry, just take a look at our Camera Replacement guide!
Poor Wire Connection
If your camera is not connecting well with your computer, it could be the wiring connection. You may have to repair or replace your camera wire. Again, to do this you will have to take apart your screen to get to the camera. Don't worry, look at our Camera Replacement guide to see how you can get to the wire!
Lindsey Baldwin
104 Reputation
1 Guide authored
CSU Fullerton, Team 1-3, Bruce Fall 2016 Member of CSU Fullerton, Team 1-3, Bruce Fall 2016
CSUF-BRUCE-F16S1G3
4 Members
108 Guides authored
2 Comments
What do you do about a pink and green screen. I sent it to be repaired under warranty and it came back with the same problem.
25skharris - Reply Share
What do you do when your laptop appears to be booting to the "white screen of death" only to find out the screen isn't working. Plugging in a second monitor allows access to the laptop.
Elizabeth Maxwell - Reply Share
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 35
All Time: 2,384
