Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
ASUS tablet won't turn on
No matter what you do, you can't get your ASUS tablet to turn on.
Battery is drained or broken
It is possible the tablet won't turn on due to a drained battery. Refer to the ASUS Transformer Battery Replacement guide to learn how to replace your battery.
Power button is broken
Power button may be stuck or malfunctioning. Refer to the ASUS Transformer Button Replacement guide to learn how to replace a faulty power button.
Camera is broken
The camera is not working normally or at all.
Lens is damaged
The camera settings may have changed during use so try to reset the these to default. If this doesn't work the lens may be damaged and needs to be replaced, refer to the ASUS Transformer Camera Lens Replacement guide on how to replace the lens.
Buttons are sticky
Buttons are stuck or not operating properly.
Buttons are broken
If buttons are jammed or not working they may need to be cleaned or replaced, refer to the ASUS Transformer Button Replacement guide to clean and replace buttons.
Tablet won't charge
Tablet does not take a charge or takes an excessive amount of time to charge
Charging port is damaged
The charging port may have been damaged over time and needs replacing. refer to the '"ASUS Transformer TF101 Charge Port Replacement ''' guide to replace the port.
HDMI connection does not work
My tablet will not connect via HDMI
HDMI Port is damaged
The HDMI/ microSD/ Headphones Jack port has been damaged and needs replacing. Refer to the MircroSD, HDMI, Headphones Audio Port Replacement guide to replace the port.
Headphones do not work
No sound plays in my headphones when they are plugged in.
Headphone Audio Port is damaged
Tablet does not recognize memory card
Nothing happens when I insert my memory card into the tablet
microSD Port is damaged
Author
with
Kristen Gismondi
110,399 Reputation
271 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
1 Comment
slow googleplay loading
patrick aula - Reply Share
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 28
All Time: 1,262
