Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
RealPad Won't Charge
The battery charge won’t hold a charge for a long time or won’t hold a charge at all. The tablet will not charge even if it’s plugged in. The tablet will not work even if it’s plugged in.
Faulty Charging
If your tablet won’t charge, check to see if the cable is fully plugged into the tablet. Also, make sure that the cable is fully plugged into the wall. Try a different outlet for your device because the outlet may be damaged or the fuse may have blown. The charging cable you are using may be defective, try using it on another device. If you don’t have another device try purchasing a new cable.
Operating System is Outdated
Your tablet software may be out of date, to make sure it isn't follow these instructions:
  1. Connect to wifi
  2. Go to"Settings"
  3. Go to "General"
  4. Go to "About device"
  5. Go to"Software update"
  6. Tap "Check for updates"
  7. If there is an update available then "Update" will pop up
  8. Tap "Install"
Faulty Battery
If your tablet will not hold a charge or won’t fully charge, then it is most likely due to a faulty battery. Follow this guide to help you replace the battery.
Faulty Charging Port
If none of the options above worked it is most likely because your charging port is damaged. Follow this [http://|guide] to replace it.
Tablet has no audio
The tablet doesn’t play any sort of audio
Tablet is on mute
Make sure your tablet is not on mute.To make sure the tablet is not on mute you want to got to settings and then audio, to turn up volume. Or you can edit volume by using buttons on the right side of the device.
Tablet needs to Restart
Restarting the tablet may solve the audio problem, you can do so by holding down the power button and selecting restart.
Faulty speakers
If you have tried the troubleshooting methods above and you still can't hear anything then you probably have faulty speakers. For replacement of your speakers check out our replacement guide [http://|here.]
The Real Tab screen is not working
The device’s screen is hard to see clearly or it is unresponsive
Low Brightness
You may have a hard time viewing the screen because the brightness level is too low. In this case you must go into the device settings application, find the brightness level setting, and increase the brightness.
Unresponsive Screen
The screen may be frozen or is unresponsive to touch. In this case you will need to do a hard restart. This will reboot the device and hopefully fix the problem. To hard restart, hold down the volume button and the home button until device shuts off. Power device back on after five minutes and check the screen
Faulty Screen
If the device’s screen is still unresponsive or possibly broken, the next step is to replace the screen. Replacing the screen is a fairly easy process and requires ten minutes, simple tools, and a steady hand. Click [http://|here] for the screen replacement guide.
Won't Connect to Internet
Your Wifi Shows "Excellent"yet you cannot access the internet, or it won't connect due to authenticating Problems.
Faulty Connection
If your tablet won't connect to the internet, you have a faulty connection. To fix this you can:
  • Restart your tablet.
  • Update your firmware and any apps.To figure out how to update your firmware go here.
  • Check the time and date on tablet, to make sure it is correct.
  • If none of the former work, then you want to Hard Reset your device. To hard reset your device hold down the volume button and the home button until device shuts off.
Faulty Signal
If your tablet is connected to the wifi, but there is no internet then you have a faulty signal. To quickly fix this you want to manually change your network from 3G to 2G. To do this:
  1. First go to Settings in your device.
  2. Then go to More Networks in the Connection settings.
  3. Once there go to Mobile Networks, then find the Network Mode.
  4. After that change the Network from 3G to 2G.
If the problem persists go [http://|here.]
Faulty Wifi Module
If all the previous options do not work, then your wifi module might be faulty. You will need to replace your motherboard, by following this [http://|guide.]
Author
with
Alana Escue
425 Reputation
3 Guides authored
13 Comments
I need a batterie for realpad MA7BX2
markus - Reply Share
screen has a fastboot mode on it will not do nothing
firebase71 - Reply Share
My name is Susan Owens my email is sasondo42@yahoo.com My real pad is I believe 6 years old it work until last Tuesday. Now it's doesn't. It charges and turns on but a message pop up saying launched 4 is not working. How do I fix that
sasondo42 - Reply Share
my ipad says that launcher 4 has stopped .. how can I fix it
Glenda lawson - Reply Share
how do you go about resetting your pin if your family member lost it and can’t start it up? It goes to the enter pin number upon start up but nobody knows what the pin is. Help?
Bill Wiley - Reply Share
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 17
All Time: 2,503
