Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Fog lights won't turn on
Burnt fuses
Fuses are the bridge between the car's battery and the electrical components of the car. They prevent any one device from drawing too much current and blowing up the circuit. Burnt fuses, though, will cause a device to stop functioning completely. Check the fuse box to see if any of the fuses have burnt up.
Burnt out light
Fog light filaments are very delicate and break easily. If it is broken, there will be no current flowing to the bulb, and it will not turn on. You will need to replace the light bulb.
Speaker is making a funny sound or doesn't work
Burnt fuses
Blown speaker
If a speaker is played too loudly or with too much bass, it can be "blown out." This means that the sound is either fuzzy or completely gone. This usually means that the speaker needs to be replaced. Please refer to the speaker replacement guide for more information on how to replace the speaker.
Dome lights stop working
Burnt fuses
Burnt out lights
Dome lights have fragile filaments that break easily. If they break, the circuit is incomplete and the lights won't turn on. Please refer to the dome light replacement guide for more information on how to replace the dome lights.
Stereo stops working
Burnt fuses
Bad head unit
Radio head units can be very fragile. A number of things can damage them, including playing music too loud, improper installation, old age, and physical damage. Please refer to the radio head replacement guide for more information on how to replace the radio head unit.
Blown speaker
When should the oil be changed?
Approximately every 5000 miles
If it has been 5000 miles since the last oil change, it is time for a replacement. Please refer to the oil change guide for more information on how to change the oil.
The vehicle vibrates when braking
The brakes pads are worn too far
The brake pads need to be replaced.
The Rotors are bent out of shape
The rotors either need to be turned (machined straight) or replaced.
The vehicle makes harsh noises when engine is running
The vehicle makes loud knocking noises. Engine vibration is greater than normal.
The engine air filter is dirty
The engine air filter is dirty and needs to be replaced or cleaned.
Worn Spark Plugs
The spark plugs are worn and failing to spark consistently. They need to be
replaced.
The vehicle tends to drift to one side of the road
The tires have worn unevenly
The tires may have worn unevenly, and need to be rotated.
The wheel alignment is off
The alignment may be off from center, or has shifted slightly. The wheels must be realigned.
A wheel bearing is worn and loose
A wheel bearing may be loose, causing a wheel to wobble and the car to drive inconsistently. The bearing should be replaced.
The brake pedal has little resistance
There is little or no resistance when pushing on the pedal.
The brake lines are leaking
The break lines could be damaged and leaking or the fittings are loose. To check have someone push repetitively on pedal while another is under the car listening for leak. It should make a gurgling or spitting sound.
The master cylinder or slave cylinder is defective
The master cylinder (at the pedal) or slave cylinder (one at each wheel) could be defective and have fluid bypassing the plunger. This is difficult to detect and should be brought to a mechanic.
The vehicle will not start when key is turned
The battery is dead
If the vehicle makes a clicking noise when key is turned then the battery is most likely dead. Replace or charge the battery. Check the battery replacement guide for more information.
Starter is broken
If one distinct loud click is heard when the key is turned then the starter solenoid may be broken. Replace solenoid, part number found in vehicle owners manual.
Battery is disconnected
If no noise is heard when the key is turned the battery is disconnected. Check for corrosion on battery leads or if the leads became loose.
Author
with
sdwelsh
187 Reputation
1 Guide authored
Cal Poly, Team 8-2, Regan Spring 2015 Member of Cal Poly, Team 8-2, Regan Spring 2015
CPSU-REGAN-S15S8G2
5 Members
84 Guides authored
4 Comments
While driving my 2013 scion tc. Standard. I hear and feel grinding what can it be
luellen smith - Reply Share
My brake light aren’t working and I’m not able to take me car out of gear I hook it up to a car scanner and it said I was my brake light switch so I replaced it with a new on and they still don’t wor and I checked all my fuses to make sure they weren’t blown and they r all fine do u have any idea what it might be
oscardavila9 - Reply Share
Is there a way to adjust the clutch???
Rob Worobetz - Reply Share
My 2013 Scion FRS won't start sometimes. The battery in the key fob is fine, I get a clicking sound but no starting. This happens from time to time. Any suggestions as to what I can do? I checked around a supposedly Scion has a program fix for the 2014 FRS's on BUT ABSOLUTELY NOTING FOR THE 2013! I am ready to dump this car. Any help would be greatly appreciated. Thank you in advance
Francie Long - Reply Share
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 30
All Time: 4,637
