This teardown is not a repair guide. To repair your iPhone 12, use our service manual.
    1. iPhone 12  Teardown, Remove the SIM: step 1, image 1 of 2 iPhone 12  Teardown, Remove the SIM: step 1, image 2 of 2
      • Remove the SIM Card tray using a SIM Card eject tool
      Ask FixBot
    2. iPhone 12  Teardown, Unscrew the lower screws: step 2, image 1 of 3 iPhone 12  Teardown, Unscrew the lower screws: step 2, image 2 of 3 iPhone 12  Teardown, Unscrew the lower screws: step 2, image 3 of 3
      • Turn off the device
      • Unscrew the two 6.9 mm long Pentalobe screws.
      Ask FixBot
    3. iPhone 12  Teardown, Raise the display: step 3, image 1 of 3 iPhone 12  Teardown, Raise the display: step 3, image 2 of 3 iPhone 12  Teardown, Raise the display: step 3, image 3 of 3
      • Apply a heated iOpener all around the edge of the screen to loosen the adhesive under the display.
      • Lift the display with a suction cup and insert a thin object to separate the screen from the frame.
      • Slide the fine object along the entire edge to cut the adhesive.
      • Raise the display.
      Ask FixBot
    4. iPhone 12  Teardown, Disconnect the display: step 4, image 1 of 3 iPhone 12  Teardown, Disconnect the display: step 4, image 2 of 3 iPhone 12  Teardown, Disconnect the display: step 4, image 3 of 3
      • Remove the 6 Phillips # 00 screws.
      • With a spudger or with your fingernails, lift the two connectors.
      • Lift the connector underneath.
      • Disconnect the display connector.
      Ask FixBot
    5. iPhone 12  Teardown, Remove the rear camera: step 5, image 1 of 3 iPhone 12  Teardown, Remove the rear camera: step 5, image 2 of 3 iPhone 12  Teardown, Remove the rear camera: step 5, image 3 of 3
      • Unscrew the 4 Phillips # 00 screws.
      • With a spudger or fingernails disconnect the two rear camera connectors.
      • Remove the rear camera.
      Ask FixBot
    6. iPhone 12  Teardown, Remove the front camera.: step 6, image 1 of 2 iPhone 12  Teardown, Remove the front camera.: step 6, image 2 of 2
      • With a spudger or fingernails to disconnect the three connectors that connect the front camera.
      • Remove the front camera.
      Ask FixBot
    7. iPhone 12  Teardown, Remove the battery holder: step 7, image 1 of 2 iPhone 12  Teardown, Remove the battery holder: step 7, image 2 of 2
      • With a spudger or fingernails disconnect the battery holder connector.
      • Unscrew the 3 Phillips # 00 screws.
      • Remove the battery holder.
      Ask FixBot
    8. iPhone 12  Teardown, Remove the camera flash: step 8, image 1 of 1
      • With a spudger or fingernails disconnect the rear camera flash connector.
      • Unscrew the 2 Phillips # 00 screws.
      • Remove the rear camera flash.
      Ask FixBot
    9. iPhone 12  Teardown, Remove the SIM card holder: step 9, image 1 of 3 iPhone 12  Teardown, Remove the SIM card holder: step 9, image 2 of 3 iPhone 12  Teardown, Remove the SIM card holder: step 9, image 3 of 3
      • Unscrew the 2 screw holders with the suitable screwdriver.
      • With a spudger or fingernails to disconnect the SIM card holder connector.
      • Remove the SIM card holder.
      Ask FixBot
    10. iPhone 12  Teardown, Remove the battery logic board: step 10, image 1 of 2 iPhone 12  Teardown, Remove the battery logic board: step 10, image 2 of 2
      • Remove the 2 Phillips # 00 screws.
      • With a spudger or fingernails disconnect the 3 battery connectors.
      • Unscrew the screw holder with a standoff screwdriver for iphone.
      • Remove the film with a spudger.
      • Attention this last step is necessary to remove the logic board.
      • Remove the logic board.
      Ask FixBot
    11. iPhone 12  Teardown, Remove the speaker: step 11, image 1 of 2 iPhone 12  Teardown, Remove the speaker: step 11, image 2 of 2
      • Unscrew the 5 Phillips # 00 screws.
      • Remove the speaker.
      Ask FixBot
    12. iPhone 12  Teardown, Remove the taptic engine: step 12, image 1 of 2 iPhone 12  Teardown, Remove the taptic engine: step 12, image 2 of 2
      • Remove the 2 screw holders with a standoff screwdriver for iphone
      • Remove the taptic engine connector with a spudger or fingernail.
      • Remove the taptic engine.
      Ask FixBot
    13. iPhone 12  Teardown, Remove the battery: step 13, image 1 of 2 iPhone 12  Teardown, Remove the battery: step 13, image 2 of 2
      • Remove the adhesive under the battery.
      • To remove the adhesive under the battery, remove the stickers marked in red in the first photo.
      • Remove the battery.
      Ask FixBot
    14. iPhone 12  Teardown, Remove the charging port: step 14, image 1 of 2 iPhone 12  Teardown, Remove the charging port: step 14, image 2 of 2
      • Unscrew 6 Phillips # 00 screws.
      • Remove the 4 screw holders with an iPhone standoff screwdriver.
      • Attention, the previous step is essential to remove the charging port.
      • Remove the charging port.
      • Be careful not to make too strong, this could damage some components.
      Ask FixBot
    15. iPhone 12  Teardown: step 15, image 1 of 1
      • And here are all the components that make up the new iPhone 12.
      Ask FixBot
Special thanks to these translators:
it en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Andrea Alfani
8,777 Reputation
5 Guides authored
SussyFixers Member of SussyFixers
Community
3 Members
60 Guides authored
8 Guide Comments
I had problem with nfc. When it was changed. Have any solution?
Ak H - Reply Share
I don't see any mentioning of the microphone, Is the Microphone an integral part of the charging port harnes?
Paal Halvorsen - Reply Share
This guide is missing A LOT of steps
Jason Oestrike​ - Reply Share
This is definitely not a US iPhone 12! e careful as the antenna can tear easily and potentially ruin a motherboard.
Kyle Morrell - Reply Share
>disconnect battery connector
>disconnetct 3 battery connectors
wtf?)) why do you call any FPC "battery connector"? so NPC
Джокер Богданофф - Reply Share
Past 24 Hours: 73
Past 7 Days: 494
Past 30 Days: 2,128
All Time: 87,054
