Introduction
Go to step 1 ↓
This is the teardown for a Clamcase for iPad 2.
Tools
This teardown is not a repair guide. To repair your iPad ClamCase, use our service manual.
    1. iPad ClamCase, iPad ClamCase: step 1, image 1 of 2 iPad ClamCase, iPad ClamCase: step 1, image 2 of 2
      • You can skip the first 2 steps if you don't want to detach the upper and keyboard covers from each other.
      • Open the case and unpeel the 2 black stickers in the top corners of the keyboard.
      • This will reveal the 6 screws that attach the upper cover to the keyboard cover.
      Ask FixBot
    2. iPad ClamCase: step 2, image 1 of 2 iPad ClamCase: step 2, image 2 of 2
      • Use the T9 Torx screwdriver to unscrew the 2 bigger screws in the middle of each side.
      • Use the T6 Torx screwdriver to unscrew the remaining 4 screws.
      Ask FixBot
    3. iPad ClamCase: step 3, image 1 of 2 iPad ClamCase: step 3, image 2 of 2
      • Turn the keyboard cover over so the bottom is facing up. Manually remove the thin black covering that is attached to the bottom.
      • Be patient, the thin black covering might be really stuck to the bottom.
      Ask FixBot
    4. iPad ClamCase: step 4, image 1 of 1
      • Once the thin black covering is removed, you will see 15 screws.
      • Use the T6 Torx screwdriver to remove the screws.
      Ask FixBot
    5. iPad ClamCase: step 5, image 1 of 1
      • Once the screws are removed, lift off the bottom panel to access the keyboard and battery.
      Ask FixBot
    6. iPad ClamCase: step 6, image 1 of 1
      • You are done.
      Ask FixBot
Izmet Barranco
213 Reputation
1 Guide authored
2 Guide Comments
Awesome! I used this guide to disassemble my clam case and repair some nonfunctional keys. Thanks!
justin duff - Reply Share
Thanks for the dis-assembly guide. Justin, what did you have to do to fix the keys that were not working. I have on with a few keys not working, not even intermittently.
dick haynes - Reply Share
Past 24 Hours: 3
Past 7 Days: 9
Past 30 Days: 42
All Time: 8,340
