This teardown is not a repair guide. To repair your Xbox, use our service manual.
    1. Xbox Teardown, Taking of the Top: step 1, image 1 of 1
      • Flip over the Xbox to where it shows the bar codes. Take of the black grips. Also scratch around where it has the stickers to find the screws there are a total of six, 2 of the screws are within the stickers.
      Ask FixBot
    2. Xbox Teardown, The Top: step 2, image 1 of 1
      • (This photo is not mine it was from another ifixit and i will use 5 photos from them since i couldn't find the ones i took)
      • When you get the screws off use the spudger to get it open by finding a crack that goes all around the xbox
      Ask FixBot
    3. Xbox Teardown, Removing the Hard Drive pt1: step 3, image 1 of 1
      • After you take of the top you will see all the circuits.
      • Look around and you will find 3 screws that are holding down the disc drive and remove them.
      Ask FixBot
    4. Xbox Teardown, Removing the Hard Drive pt2: step 4, image 1 of 1
      • When you do that just take off the disc drive depending on what you are trying to fix just unplug the wires going to it and set it aside.
      Ask FixBot
    5. Xbox Teardown, Removing the Disc Drive: step 5, image 1 of 1
      • Unplug any wires that seem to be poking out then take out the disc drive which should just come out.
      • Same thing if its not your focus just put it to the side.
      Ask FixBot
    6. Xbox Teardown, The Ribbon: step 6, image 1 of 1
      • The rest are my pictures
      • Remove the ribbon carefully
      Ask FixBot
    7. Xbox Teardown, The Rainbow Wire: step 7, image 1 of 1
      • Somewhere on the motherboard there will be a multi-colored wires that are together and just simply unplug it.
      Ask FixBot
    8. Xbox Teardown, Removing the Transformers: step 8, image 1 of 1
      • To the left of the Rainbow wire there are a lot of transformers which we will need to take out.
      • There will be screws holding it down so just look around the transformers.
      • Disconnect any wires that are connected to it before picking it up.
      • Set it aside if its not what you are going for.
      Ask FixBot
    9. Xbox Teardown, The Motherboard: step 9, image 1 of 1
      • When the transformers are gone look around the motherboard which should be the last electronic left.
      • There also will be screws around,when you find them unscrew them and all you have to do know is carefully take out the motherboard
      • Then your done at taking out the motherboard.
      Ask FixBot
Justin Moreno
219 Reputation
1 Guide authored
1 Guide Comment
you forgot to mention the fan shroud, which, if i remember correctly is a bit tricky to remove
pantsaremyfriend - Reply Share
Past 24 Hours: 5
Past 7 Days: 29
Past 30 Days: 120
All Time: 8,992
