This teardown is not a repair guide. To repair your Xbox, use our service manual.
    1. Xbox Teardown, Xbox Teardown: step 1, image 1 of 2 Xbox Teardown, Xbox Teardown: step 1, image 2 of 2
      • The Xbox, not as pretty as it was when I bought it 7 years ago.
      Ask FixBot
    2. Xbox Teardown: step 2, image 1 of 2 Xbox Teardown: step 2, image 2 of 2
      Tool used on this step:
      Heavy-Duty Spudger
      Buy
      • To begin dissasembly, flip the console so it is upside-down.
      • Remove the 4 rubber pads with a flathead screwdriver, or a heavy duty spudger. It takes a little force to get them off.
      Ask FixBot
    3. Xbox Teardown: step 3, image 1 of 3 Xbox Teardown: step 3, image 2 of 3 Xbox Teardown: step 3, image 3 of 3
      • Doing this should reveal 4 T10 Torx Screws, But, there are 2 more hidden by stickers.
      • The hidden screws are shown in yellow.
      • Removing the 2 screws hidden by stickers will void your warranty, even though I'm sure that your warranty has already expired.
      Ask FixBot
    4. Xbox Teardown: step 4, image 1 of 2 Xbox Teardown: step 4, image 2 of 2
      • Remove the 6 T10 Screws.
      • Hmm, where heve we seen these before?
      • My Xbox 360 Teardown, of course!
      Ask FixBot
    5. Xbox Teardown: step 5, image 1 of 3 Xbox Teardown: step 5, image 2 of 3 Xbox Teardown: step 5, image 3 of 3
      • To remove the top half of the console, flip it upright and use a flathead screwdriver to separate the two halves.
      Ask FixBot
    6. Xbox Teardown: step 6, image 1 of 2 Xbox Teardown: step 6, image 2 of 2
      • Simply lift the top half off.
      • This reveals the drives.
      • From Left To Right: The DVD-ROM Drive, And A Seagate 8GB Parallel ATA Drive
      Ask FixBot
    7. Xbox Teardown: step 7, image 1 of 2 Xbox Teardown: step 7, image 2 of 2
      • Removing the drives
      • Start by removing the ATA Cable from both drives. There might be a piece of double sided tape holding the ribbon cable in place.
      Ask FixBot
    8. Xbox Teardown: step 8, image 1 of 2 Xbox Teardown: step 8, image 2 of 2
      • Next, remove the power cables from the drives.
      • The hard drive uses a standard molex connector for power, but the DVD-ROM drive uses a proprietary xbox connector similar to that of the xbox 360.
      Ask FixBot
    9. Xbox Teardown: step 9, image 1 of 2 Xbox Teardown: step 9, image 2 of 2
      • Remove the DVD-ROM power cable.
      Ask FixBot
    10. Xbox Teardown: step 10, image 1 of 1
      • Before we can continue, there are 3 T8 Torx screws hidden here that we need to remove.
      Ask FixBot
    11. Xbox Teardown: step 11, image 1 of 2 Xbox Teardown: step 11, image 2 of 2
      • Lift the hard drive and the plastic attatched to it out, you will need to route the power cable so you can get it out.
      Ask FixBot
    12. Xbox Teardown: step 12, image 1 of 3 Xbox Teardown: step 12, image 2 of 3 Xbox Teardown: step 12, image 3 of 3
      • Removing the DVD-ROM drive.
      • Lift the DVD-ROM drive and the plastic attached to it out. This reveals the logic board.
      Ask FixBot
    13. Xbox Teardown: step 13, image 1 of 1
      • Here's a view of the logic board.
      Ask FixBot
    14. Xbox Teardown: step 14, image 1 of 2 Xbox Teardown: step 14, image 2 of 2
      • Removing the heatsinks.
      • The big one to the right, is the CPU, the smaller one to the left is for the GPU.
      • Lift the black tab up on the cpu heatsink. This will release the tension on the chip.
      • Next, use a flathead screwdriver to remove the clip. Then lift the CPU heatsink out (this may take some force).
      Ask FixBot
    15. Xbox Teardown: step 15, image 1 of 1
      • The CPU
      • So What's Under Door Number One?
      • An Intel Pentium III CPU running at 733Mhz.
      • This is actualy a surprise, because almost every other console out there uses an IBM PowerPC CPU. This makes us wonder, could this console emulate Windows?
      • It also raises the question, why did Microsoft switch to PowerPC, around the same time Apple switched to Intel?
      Ask FixBot
    16. Xbox Teardown: step 16, image 1 of 3 Xbox Teardown: step 16, image 2 of 3 Xbox Teardown: step 16, image 3 of 3
      • The GPU
      • Push on the tab on the GPU heatsink. While doing this, use a flathead screwdriver to push on the tab so when released, it clears the latch
      • Be careful, if you break any one of these tabs, then, your heatsinks will not be usable, and your console will fry, if you try to run it.
      • Removing the GPU heatsink, reveals an NVIDIA NV2A.
      Ask FixBot
    17. Xbox Teardown: step 17, image 1 of 1
      • The Logic Board Overview:
      • The CPU: An Integrated Intel Pentium III CPU Clocked at 733Mhz with a 100Mhz Front Side Bus
      • The GPU: Nvidia NV2A running at 233Mhz
      • The Power Supply: Be Carefull When Working on this, you can get shocked by this if you touch it. The power connector is similar to that of an AT Power Supply found in 90's computers. It can supply 100 watts.
      • The ATA Header: This connects both drives to the Xbox Logic Board.
      • The A/V Ports
      • The Ethernet Port
      Ask FixBot
Chris Green
38,435 Reputation
49 Guides authored
Master Techs Member of Master Techs
Community
335 Members
8,260 Guides authored
11 Guide Comments
Since the CPU has only 128kB L2 cache, it's actually the Celeron version of the Pentium III processor. Which was meant for office work, not gaming. :/
Saberus Terras - Reply Share
The original XBox was x86 largely because Microsoft had no clue what they were doing when they first designed the console. x86 is a dreadful architecture to work with outside of PCs, and even in the PC industry, x86 isn't really all that wonderful and is only in use because of how the PC market works. Apple knew if they stuck with PPC much longer on Macs they'd lose critical mass with software developers and they'd end up selling very expensive paperweights in a few years if they didn't do something.
As for game consoles: PPC has been demonstrated and proven time and time again to be technically superior to x86. To this day (April 2013) this is still holding true. Microsoft ditched x86 for PPC in the 360 when they realized basing the XBox on the x86 architecture was a horrible idea, both power and power-consumption-wise.
Alas, the next XBox and the PS4 are both going x86, whereas Nintendo is wisely staying PPC with the Wii U.
Yaro - Reply Share
Lol.
I am from the future and here to tell you how stupid that statement was.
Sources:
Xbox One - AMD Bulldozer
PlayStation 4 - AMD Bulldozer
Bobby Dazzler - Reply Share
Oh, hello there Bob!
Still using AMD on upgraded tech, called Xbox Scorpio and PlayStation 4 Pro :P
Have fun,
Blinx
Blinx - Reply Share
Oh hey and now Nintendo moved to Arm... Why leave PPC? Well, you know... Mobility and less power consumption...
Adriano Brito - Reply Share
Past 24 Hours: 3
Past 7 Days: 42
Past 30 Days: 219
All Time: 73,956
