This teardown is not a repair guide. To repair your VIA GO, use our service manual.
  1. VIA GO Teardown, Overview: step 1, image 1 of 3 VIA GO Teardown, Overview: step 1, image 2 of 3 VIA GO Teardown, Overview: step 1, image 3 of 3
    • USB and audio ports at front and rest of I/O are at the back. power button is on top.
  2. VIA GO Teardown, bottom screws: step 2, image 1 of 1
    • Remove four (phillips) screws on the bottom of the device, these are located inside of rubber feet.
  3. VIA GO Teardown, motherboard: step 3, image 1 of 3 VIA GO Teardown, motherboard: step 3, image 2 of 3 VIA GO Teardown, motherboard: step 3, image 3 of 3
    • remove screws that hold motherboard in the case.
    • LPDDR3 slot (there is no internal memory).
    • M.2 slot with Intel 3160NGW (Dual-band AC-WiFi + BT)
    • 20-pin connector for external SATA hard drive.
  4. VIA GO Teardown, CPU and heatsink: step 4, image 1 of 3 VIA GO Teardown, CPU and heatsink: step 4, image 2 of 3 VIA GO Teardown, CPU and heatsink: step 4, image 3 of 3
    • screws to remove fan assembly
    • screws to remove heatsink
    • RTC battery
    • eMMC (SD) chip
    • power button
  5. VIA GO Teardown, CPU without heatsink: step 5, image 1 of 2 VIA GO Teardown, CPU without heatsink: step 5, image 2 of 2
    • closeup of Intel N3010 SoC and eMMC chip.
  6. VIA GO Teardown, motherboard (without memory): step 6, image 1 of 3 VIA GO Teardown, motherboard (without memory): step 6, image 2 of 3 VIA GO Teardown, motherboard (without memory): step 6, image 3 of 3
    • component overview. also closeup of 20-pin external sata connector.
Artur Huhtaniemi
373 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 70
All Time: 604
