Introduction
Go to step 1 ↓
My microscope is old (very old) and before throwing it away, why not teardown it?
NB: If you notice that there's too many errors (in language, mostly), please correct me. Thanks.
Tools
This teardown is not a repair guide. To repair your Toy Microscope, use our service manual.
    1. Toy Microscope Teardown, Toy Microscope Teardown: step 1, image 1 of 3 Toy Microscope Teardown, Toy Microscope Teardown: step 1, image 2 of 3 Toy Microscope Teardown, Toy Microscope Teardown: step 1, image 3 of 3
      • The microscope package (that's right, some items were lost and the box suffered)
      • The back of the box with all its items.
      • The useful piece of the microscope package: the microscope (not very surprising...)
      Ask FixBot
    2. Toy Microscope Teardown: step 2, image 1 of 3 Toy Microscope Teardown: step 2, image 2 of 3 Toy Microscope Teardown: step 2, image 3 of 3
      • Now, let's begin the operation: we'll begin with the pedestal. No need for screwdrivers, you just have to pull it.
      • After this, there's a screw. Let's remove it.
      • Once you did it, the battery compartment can be removed.
      • Note: if you want to remove the pedestal completely, you may need to cut the both wires.
      • Note 2: from now on, the microscope will be more difficult to reassemble.
      Ask FixBot
    3. Toy Microscope Teardown: step 3, image 1 of 3 Toy Microscope Teardown: step 3, image 2 of 3 Toy Microscope Teardown: step 3, image 3 of 3
      • Then, this rotative piece is, in a side, a mirror and in the another, a lamp (hence the 1.5x2 batteries in the step 2).
      • To remove it, you need pull a side. The rest will come alone.
      • The picture is a little fuzzy but we can see:
      • The bulb.
      • The support of this rotative piece.
      • The battery.
      • The cover which prevents the bulb to fall.
      • The mirror and the bulb location
      Ask FixBot
    4. Toy Microscope Teardown: step 4, image 1 of 2 Toy Microscope Teardown: step 4, image 2 of 2
      • Now, remove the big Phillips screw here (actually, you can loosen it then remove the nut in the other side). Don't be worried if it's a little hard to pull the screw.
      Ask FixBot
    5. Toy Microscope Teardown: step 5, image 1 of 2 Toy Microscope Teardown: step 5, image 2 of 2
      • Next step: remove the plate (it's here that you put the item to analyze): 2 Phillips screws.
      Ask FixBot
    6. Toy Microscope Teardown: step 6, image 1 of 3 Toy Microscope Teardown: step 6, image 2 of 3 Toy Microscope Teardown: step 6, image 3 of 3
      • This piece allows you to change the growth. 1 screw.
      • If you turn this piece, the growth will be modified thanks to these magnifying glasses (red circles)
      • To remove them, you need to use a sharp piece (e.g a pen) and press on the 3 holes marked on blue.
      Ask FixBot
    7. Toy Microscope Teardown: step 7, image 1 of 1
      • You can easily pull off the black part.
      Ask FixBot
    8. Toy Microscope Teardown: step 8, image 1 of 1
      • After removing the black part (step 6), turn the wheel until you withdraw the lens.
      Ask FixBot
    9. Toy Microscope Teardown: step 9, image 1 of 2 Toy Microscope Teardown: step 9, image 2 of 2
      • This mechanical wheel allows you to hang over or hold off the lens in order to improve the clearness.
      • If you like unscrew whatever you find, there are 2 screws.
      Ask FixBot
    10. Toy Microscope Teardown: step 10, image 1 of 2 Toy Microscope Teardown: step 10, image 2 of 2
      • Now, let's analyze the lens.
      • You just have to pull the different parts.
      Ask FixBot
    11. Toy Microscope Teardown: step 11, image 1 of 2 Toy Microscope Teardown: step 11, image 2 of 2
      • The lens which enlarges the item to analyze from 12 to 18 times.
      • A tube, without magnifiers.
      Ask FixBot
    12. Toy Microscope Teardown: step 12, image 1 of 1
      • Here, that was the consequences when you lend me a microscope. RIP.
      • In the bottom right corner, you can see the perpetrators of this teardown.
      Ask FixBot
Bob
808 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 62
All Time: 7,501
