This teardown is not a repair guide. To repair your Breville BTA720, use our service manual.
    1. Toaster Teardown, Remove screws and pedestal: step 1, image 1 of 1
      • Remove Breville bread toaster base screws -- 14 places.
      Ask FixBot
    2. Toaster Teardown, Cut wires and remove the shell: step 2, image 1 of 2 Toaster Teardown, Cut wires and remove the shell: step 2, image 2 of 2
      • With a scissor cut the wires connecting the base and the shell.
      Ask FixBot
    3. Toaster Teardown, Remove the wire sheet: step 3, image 1 of 2 Toaster Teardown, Remove the wire sheet: step 3, image 2 of 2
      • Break up the inner shell of toaster and the wire sheet.
      Ask FixBot
    4. Toaster Teardown, Remove each parts: step 4, image 1 of 2 Toaster Teardown, Remove each parts: step 4, image 2 of 2
      • Remove all the parts of shell and base.
      Ask FixBot
    5. Toaster Teardown, Identifying parts: step 5, image 1 of 1
      • Shell
      • Base
      • Heater element -Nickel chrome wire
      • Switch assembly - ABS injection moulding
      • Circuit board
      • Wires
      • Screws
      Ask FixBot
Shuman C
130 Reputation
1 Guide authored
1 Guide Comment
Errors:
Step 1. There are 18 screws. The 4 corner screws hold in the feet. The feet must be removed to reveal 4 more screws under each rubber foot.
Step 2. The green earth wire is welded onto the cover, but can be unscrewed at the toaster end rather than cutting the wire.
MrMilf - Reply Share
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 38
All Time: 1,195
