Teardown
This teardown is not a repair guide. To repair your Surface Go 2, use our service manual.
A big part of the Surface’s thermal solution is the aluminum backshell. If they added thermal pads between the back of the CPU and PMIC area of the PCB and the case, it would definitely be a nice touch.
Ethan - May 18, 2020 Reply Share
We’ve always got modders to do that.
Strumajen - Aug 16, 2020 Reply Share
Does anyone knows if the battery for the surface go 1 is compatible with the surface go 2 and vice versa?
Odysseus - Jun 23, 2021 Reply Share
to anyone wondering, No, it's not .. But, Go 2,3,4 share the same .. battery, Display, housing, wifi antenna's ..
Stephan Schmuck - Feb 23, 2026 Reply Share
Is the LTE modem removable/swapable?
Dan - Aug 7, 2022 Reply Share
Choose a size and copy the code below to embed this guide as a small widget on your site / forum.
Past 24 Hours: 7
Past 7 Days: 77
Past 30 Days: 408
All Time: 39,715
10 Guide Comments
Ethan - Reply Share
Strumajen - Reply Share
Odysseus - Reply Share
Stephan Schmuck - Reply Share
Dan - Reply Share
